Old 11-26-2005, 11:43 PM   #1
Default front lock diff vs gear diff
Anyone know the difference between the two. I'm thinking of pulling out my one way and going with a lock or gear diff. Our track here is more box type then rounded. So the one way is not working for my type of driving. BTW, it's for my MTX 4 and also before I build my MRX 4 I'm also deciding on going the diff route. thanks
rhed is offline   Reply With Quote
Old 11-27-2005, 12:42 AM   #2
I have use them both and to lock the axel in front will get the best for me.
You can start breaking later when you have brake in all wheels, and
the car get more easy to drive.
But this will not be the best for everbody, try to find the best set up for you
i think will be good.
GIDDE is offline   Reply With Quote
Old 11-27-2005, 12:56 AM   #3
onnetz's Avatar
if you dont need breaks then generally a one way is faster than a spool(locked diff)..
the one way allows for the front tires to rotate at different speeds off power going into the corner and since the outer tire is traveling a farther distance through the corner than the inner tire, this is the fastest option, whereas the spool doesnt allow for the tires to rotate at different speeds, and this creates friction in the corner, scrubbing speed..
so.. a one way is faster but harder to drive and the spool isnt as fast but is easier to control..
I prefer to experiment until I find the right weight oil for the front diff.. that way I still have control and dont scrubb as much speed as a spool would..
I hope that made sense..
onnetz is offline   Reply With Quote
Old 11-27-2005, 01:25 PM   #4
geeunit1014's Avatar
it also depend on the track type. if ti is a wide open track, the one way will, be faster, because yuo generally need little or no brakes on big tracks. If it is a small track that needs brakes and a generally more aggresive setup, a spool can be better. but you must remember that 90% of a setup is dependent on th driver.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 11-29-2005, 01:20 PM   #5
GrandeGixxer's Avatar
On the tight track we usually run on here, we run the diff. We run 30,000 in the front diff and 10,000 or even 5,000 in the rear diff. It works out pretty well.
GrandeGixxer is offline   Reply With Quote
Square diff lock hub and gear diff oil for TT-01/R/D Drift Demon Australia For Sale/Trade 0 12-12-2006 09:34 PM
[B]Fioroni Center Diff And Front Diff And Ofna Torsion Diff For Hyper 7[/B] Imdadundada7 R/C Items: For Sale/Trade 22 08-07-2006 10:11 PM
Front Gear Diff for Ofna CD3 Pro WeatherB Nitro On-Road 7 04-20-2006 01:58 PM
one Front diff - looking for Ring Gear - TC4 bvoltz Rookie Zone 1 07-17-2005 10:33 PM
MBX front diff gear sweetpea R/C Items: Wanted to Buy 1 07-14-2003 09:55 AM
SEO by vBSEO 3.5.0
