Serpent 705
#931
reply
Thanks for your reply InitialD it is appreciated
bt
bt
#932
Re: Re: Re: Re: Gear Ratio / Setup Sheet
Originally posted by InitialD
Welcome What are you currently using? The 705 or the Impulse PRO? If you're using the old Centax clutchbell, you need the 50T (the 801420 specifically and NOT to be confused with the new Centax II 50T 902450) that comes stock with your Impulse / Impulse PRO to mesh correctly with the fixed pinions on it. The diameter of this 50T is slightly larger than the 49T, 48T and 47T 1st gear spurs normally used for the Centax clutch. With this 50T, you do not need to slant your engine to mesh the gear properly. I believe this is the reason why your 1st gear spurs are breaking... As for the 2nd speed spurs, you can use the 44T, 45T and the 46T spurs meant for the Centax clutch.
To be able to use the old Centax clutchbell on the 705, you need to use this 50T (801420) with the older 1st gear spur drive flange one way bearing (9633) that comes with the Impulse / Impulse PRO. Spacing will be correct and the pinions will mesh correctly with the spurs. The 2nd speed LC spurs on the 705 can be left as is.
Can you share your setup with the solid rear axle? What are you using in the front? One way or diff? What tires? Thanks.
HI!
I run both, I have a 705 and a Pro that is about a 705.
On my pro I did not use the shock towers. For some reason I really comfortable not using the towers and not confusing myself which hole to use. Yes, I run solid axle and solid rear. I felt more push in the car. Especially, running 13/17 and 45/49.
Here is my set up: it might not work for others, but it works great for me.
Comments: A main awesome handling and great accelration. Like what I said it kind a handle like my 8th scales. Not totally the same, but the feeling is there.
FRont Set up:
Toe in: 0
anti roll bar: 45 degree
trans: One-way
shocKs: Red w/ 30 oil hole #2
Tires: Arrows 26 width 40 shore
Rear:
Toe in: 2.5 degree
Anti rollbar: I think its .5 Soft Stock of 705
trans: Solid axle, 47 (808353) /22 (909242), belt , (6361)
Shocks: yellow 30 oil #2 hole.
Tires: CRC 35 width 42 shore
Motor: Rb 5 port 310, Novarossi S5, Nova mega Ms 5 port. All motors about the same, but in my opinoin the Novarossi has more consistency!!
Clutch: 13/17 45/49
Track: small and I will say some Medium
weather: about 75 to 85 F
Fuel; BK 25%
Like what I said it might not work for some people, but this set brings me to the main.
#934
The wiering on the streetspec takes a bit of consideration to figure out. I think most people do something similar to what I did, istall all your electronics, then bundle up your wires and use shrinkwrap to keep it together, neatly stashed on the radio plate, you can also try to wind your wires around a screwdriver or similar and then pull it out. The wire will stay "curly´" and will not be all over your car. Consider dumping the switch alltogether and just plug you battery in when using the car. This is the safe way to do it anyway. Too bad you lost you VoneR
#935
Originally posted by coastaltony
Some b*****d stole my VoneR & M-8 this past Sunday, and I am putting an Impulse StreetSpec in action.
I've never messed with one of these. Where do I store the wiring from the servos, rx pack, failsafe, on/off switch? I can try to stash it below the radio tray.
It really depends on which tray do u have.
U might have the ff:
1. stock plastic
2. Gpm graphite plate
3. Top Serpent plate
4. or the impulse pro plate, which has no mount for regular on and off switch.
The best way to do it is to pull the tray out, and make sure the antenna tube is close to the receiver. I zip tie some of the wires and place them in a neat formation. This is all up to u how u put ur wirings together.
#936
Thanks to both you guys.
I have the stock plastic radio tray.
If one of the after-market trays will work better, I am all ears.
I was informed to install the receiver
on the bottom side of the radio tray, with the connectors facing the fuel tank. (might be a pain plugging & un-plugging the battery)
As for a failsafe, use a device like the KoPropo electronic job, or do like Kyosho did and use a rubberband?
#937
Wires all nice and neat. Have the KoPropo switch & failsafe mounted.
This Impulse has a Nove Mega SX-12 rear exhaust, and the side belt appears to want to rub against the exhaust manifold.
This chassis is just about as bad as an HPI RS4 for the wires.
Any of you guys built or run a NTC3?
No wires anywhere.
No wires anywhere.
#938
#939
No wires anywhere.
No wires anywhere.
http://www.mytsn.com/products/desc.asp?prid=1852
It may be that the organisation of wires is as bad as the RS4 but it's no RS4 in terms of performance
#940
I also like the battery pack mounting which is directly behind the tank (in between the tank and radio tray support) and directly in the middle across the chassis. Good luck with the Streetspec.
#941
modellor
Hey modellor? How did you do in the recent Halifax Round 1 Summer Club Championships with the 705? I heard that overall, team Serpent did good...
#942
Re: Re: Re: Re: Re: Gear Ratio / Setup Sheet
What are your front and rear droop settings? Front and rear camber?
The stock rear sway bar is 1.5mm thick. They actually just came out with a slightly harder 2mm version (808339).
#943
Re: modellor
My local club is in Northern Ireland and so far this year the 705's have been dominating everything. I will be running mine this weekend for the first time. Had trouble finding rechargeable AAA cells here to make up a battery pack. Not gonna spend $50 for something I can make myself for $20
I can foresee a Serpent 1-2 finish in both our local club championship and the Irish National Championship . Third will probably go to the NTC3 full sponsor driver.
#944
I was planning on getting a 705, then I heard that they are releasing a 705S or something to this sort to fix some of the problems with the 705. Is this true or a bunch of BS?
Thanks,
Thanks,
#945
Re: Re: Re: Re: Re: Re: Gear Ratio / Setup Sheet
Did you install the 17T side pulley (801252) together with the 47T solid axle pulley and 22T brake pulley?
There u go I know Missed something. I used 1.5 real anti rollbar soft one. 2 mm is I think might be stiff in the rear. I tried the blade anti roll bar. I felt no suspension in the rear it was too stiff. I even used the impact wco2 stock it was just no suspension whatsoever. That might be good in Oval but not in the course. U may try 2 mm. If u run 30 to 35 width tires that 2 mm will not compensate that is really going to be stiff ur rear end. That is just not my driving style.
I did not change my side pulley I left as it is.
Here the rest of the set up I wrote it down and save it in My files:
Suspension geometry Front:
Downstops: +1mm
Set-up ride height:
Camber Left: -2mm
Camber Right: -2mm
Track-width: 199mm
Toe-in: -0 degree (toe-out)
Caster setting (mm in front): 4mm
Downstops: 7mm
Set-up ride height:
Camber Left: -2
Camber Right: -2
Spacer on upright:
Toe-in: 2.5 degree (toe-in)
