Serpent 705
#3121
Pit-Racer, that's what I call rubbing shoulders with Ralph Thanks for the cool pics.
Ooophs, I forgot it's FRIDAY
#3122
Anyway, just looking at Per-Ola Hård's description of the 200mm Euro race, I see the following:
The only real change compared to the standard car is the modified front suspension, these new parts was given to all Serpent racers at the event
Having a look at the talk back section, he says that there is a modification to the front bearing block - to change the roll centre.
Here's a link to the pic of the mod.
http://www.mytsn.com/forums/image.aspi?fiid=39117
Does that count as my Friday picture?
Cheers, Mark.
#3123
Nein.. That's out right cheating Mark
I don't think Per-Ola meant that the new front bearing block was given by Serpent. He repeated that he had to drill the new hole himself...
Like I did with MINE Yup, that was what I did and posted it a few Fridays ago... Didn't you have a look at it? Or perhaps you only look at D1 pics...
#3124
Friday Pics #1
Ok, as promised, I'll post some pics of the car... Just a pic of my recent Lola shell mounted on the 705
#3125
Friday Pics #2
Friday Pics #3
I dont remember who, but someone posted a while ago that they had a problem achieving equal track width on each side of the rear while keeping the proper camber. This problem arose on my 705 and I found that the kit came with two slightly different rear uprights. I have no means of posting a pic, but one upright was slightly more slanted on the top, causing the 7mm spacer to lean more towards the outside of the car. The overall difference in the height of the entire upright with the spacer was somewhat significantly affected. I exchanged the upright with a spare and the problem was almost fixed. I still have a slight difference in width fropm left to right. I was about to put two of the old uprights (that were 3mm higher) on the car, but I decided not to because I would not be able to get spares.
#3128
It doesn't seem to affect the handling of the car. It seems different batches of uprights have slightly different sizes.
Hey, InitialD, NICE PICS!!!!!!!!!!!!
I'm starting to think you've bought a D1
Which wheels are you using - they look dished
#3129
Arun, Mark (aka Mr. D1 ) posted about that problem.
Which upright was this? Left or right rear uprights?
I don't notice that problem too much. Perhaps I'm using a spacer less than 7 mm. I think the 7 mm spacer accentuates the problem more.
Perhaps, we should shave off the material on the uprights with a dremel so that both left and right rear uprights come to the same height...
Yes, the older uprights that are higher increases the rear roll center
#3130
If I had that amount of money, I would have gotten myself a 950 already
They are actually Speedmind wheels
I find the wheels to be very sturdy and hardy. Does not warp easily. Oh yes, if you use the FC steering blocks, the Speedmind fronts will clear the front knuckles. The older set of knuckles will rub the inner rim.
Still, I cut a piece of lexan in a shape of the hex to act as a spacer to get it to clear the steering turnbuckles.
#3131
Are you saying that as a compliment or are you wanting me to post more pics
Of course they are dished No camera tricks here
I think I may build a 950 come winter - someone is interested in buying my big 400mm lens, so there'll be some spare cash for such a project!
Do you know where I can get these wheels in Europe?
Ta for the info on the Dodge body - I'll take a look at getting a couple of those.
Patched my Vectra body back together again - I super-glued some strips of lexan under the areas which are cracked to try and get the rigidity back.
Hopefully I'll hit the track again tomorrow.
Cheers, Mark.
#3133
#3134
Damn... So no more cool D1 pics from you, huh?
No idea. However, some GRP flavours come with dished wheels. I know Ellegi has as FAST tires too.
Small lexan pieces are very handy to have in the toolbox for these kind of things...
Cheers, Mark.
#3135
Don't worry, the D1 pictures are not affected by the sale of the 400mm
