Return to Racing and advice for new season
#16
hi all
i 'am also new to 1/8 on road in the uk coming from offroad, i have just got a
serpent 977 and a novarossi keep on and will be runing at the halifax track.
has anyone got any tyre advice as this area is new to me,do i need a tyre truer
if so how do i use it and what size should thay be .also my body did not come
with the rear wing is this normal do i need one.if so what hight should it be and
where can i get one in the uk.
thanks rick..
thanks rick..
Elite RC in Halifax will be able to set you up with the rear trim tab/wing, and yes you need one for sure, they make a HUGE difference.
Tyres are available also from Elite RC in Halifax, I wouldn't be too fussed about buying a truer for racing at club level at first.
The rear wing height, depends on track conditions and the car, but around 5mm above the body is a good place to start.
James.
#17
James - will there be any Shelherd drivers driving the Velox E8 at the National this year in the electric 1/8th category?
#18
hi all
thanks rick..
thanks rick..
On tyres you can run them straight out of the box especially as a newcomer. If you go for a tyre truer then most of the trackside support dealers should be able to help you there and advise on usage. Technically its better for the gearing if you keep to a specific diameter difference between front and rear although this always seems to vary depending on who you speak to but I think its a 7mm difference on a Serpent ?
Personally I've always hated the thought of reducing the sizes out of the box with a truer as you kind of feel you aren't getting value for money, but there again if you are chasing performance its something you will start to play with to improve handling and reduce lap times.
#19
thanks for the reply guys..
so are all new tyres the same diammator regardless of brand.
