leak from flywheel
leak from flywheel
i noticed some oil/fuel coming out from the flywheel. what the hell? what could be the problem? and i also hear this ssssshhhhhhhhhhhh.... for like 5 seconds then gone, then sssshhhhhhh.... and gone. what is this sound?
If it is an NR engine then it is that the front bearing is mis aligned. Get someone with a bearing extraction tool and oven to help you!
However, some engine (eg.HPI .15SS) simply leak whatever you do to it!
it has to be the front bearing.
should i buy a new bearings or what? can u guys give me a step by step instruction on how to fix this? i would really appreciate it. thanks.
http://www.rbproducts.com/rbww/faqrb...gebearings.htm
very helpful website! thanks fellas. btw, i have kyosho GS11R engine.
