Mugen MRX6
#256
M3 Bearing steel Parallel Pins Dowel Pins Cylindrical Pins Position Pins DIN7 | eBay
Bearing steel pins. If they are a bit softer then they will keep the outdrives better alive
#257
I'll worry about this later. I need to pick up servos and a motor for the car. Looking at a Rex Legend 9. I wonder if this and wc35 have any parts compatibility for future upgrading of internals.
#259
Any of you guys find a billet servo horn that is a direct fit?
#260
Just about everyone told me that a low profile servo would be fine, it's not. I bought a low profile servo for the throttle and the harness rubs. It can be forced into place and work, but it's not ideal. It would be ok on steering side from what I can tell. Moral of the story, unless the harness shoots out the back, don't get a low pro for throttle.
#261
Hi guys from italia, I also declare low profile servant, can not mount on gas-brake, there is no space for cables, I wanted to mount futaba to recover weight but impossible. Now I am mounting titanium ergal kit kits to break weight and center of gravity
#262
Low friction pulleys worth getting? Anyone with feedback?
#263
Do you think you need a possible 0.1 sec gain to be a winner? If not then those pulleys are a waiste.
#264
I agree with rolef 100%
#265
I also confirm I put only kevlar pulleys does not need much.
Differences and improvements can only be noted if a complete preparation is combined with several optional options, so you can see improvements even if you are not expert pilots!
#266
And they are UGGGGG LEEEE!
#267
Thanks for the feedback. I wasn't looking for better times so much. Was more after durability and such. The color is easy, I'll change them up.
I got a good deal, I'll let you guys know how they do.
#268
If I can advise, to increase shear life kewlar wet belts with teflon grease
#269
The new pulleys seem to have an extra in the bag. I'll have to look closer, looks like they may give you an optional ratio in there.
#270
Only use spray Silicon on the belts
Don
Don
