setting up clutch
setting up clutch
does anyone want to explain why my clutch isnt setting up right? first off im running an os 18 tz with an xray nt1 clutch. after putting on the fly wheel there is less room to tighten the nut. also the rest of the asseblally just seems tight. without running any shims the clutch bell is almost locked already. its dragging the clutches
Is the tip of the cone sticking out of the flywheel? With Xray you must use a short cone.
as for the lack of clutch gap, I think the issue is how far the cone is sticking out behind the flywheel.
assuming the cone is contacting the front bearing, how much gap do you have between the flywheel and engine bearing? this is usually 1mm or so, if it is 4 or 5 mm's then you really want a different cone, or you will need to add small shims to space the thrust bearing out from the engine.
the nt1 manual is finicky about the cone not extending out beyond the flywheel, I guess there is not clearance on a 1/10 nut compared to 1/8 equivalent. so to get a good non-slip grip on the cone you will need a narrow cone, which xray provide as an option.
Wait wait, add shims where? And the come sits about 1 mm out the back of the fly wheel. My big issue is that I use a few small spacers behind the main large Bering inside the clutch bell housing so that the whole thing is fully locked and engaged when I tighten the top but. If I have no shims at all ... Then there is no point to a clutch. This worked for quite some time but now, once the engine warns up the clurch is always locked. Although this may be because the clutches are fucked the im issue was present before the clutches got fucked up. Never had this problem on my other engine . I simply took the whole set up shims where they were and put it on the os .18 and there was an issue
Why? The huge amount of play you will get w/o shims under the inner bearing will still create the same clutchgap, only the clutchbell will toutch the shoe from time to time with idle and the thrust bearing will damage quickly.
Wait wait, add shims where? And the come sits about 1 mm out the back of the fly wheel. My big issue is that I use a few small spacers behind the main large Bering inside the clutch bell housing so that the whole thing is fully locked and engaged when I tighten the top but. ...
...I simply took the whole set up shims where they were and put it on the os .18 and there was an issue
first set the gap between the shoe and bell to 0.6-0.7mm, this is done with shims between the thrust bearing and its retainer. this is done with no inner bearing so you can get full contact between the shoe and bell.
second set the clearance with all parts assembled, according to hudy this should be 0.05-1.5mm, i tend to use a larger 0.1-.2mm on my car but it isn't an xray.
it sounds like you just need to re-shim, this is normal when you switch a clutch between engines.
Here a nice instruction vid how to setup a clutch:
https://www.youtube.com/watch?v=7wjogF57xpo
And indeed the amount of shims on both places may differ between engines and even on the same engine when rebuilding the clutch.
NT1 Centex style clutch. W/o shims installed clutch assembly to check endplay. You don't have room to assemble. Probably the clutch bell hitting the retainer and spring. Preload the spring all the way down, then 2 1/2 turns out. should spin freely.
before installing a whole new clutch, try getting this one setup properly with a new clutch shoe. some experimentation with this one will make using a new one less problematic.
Also, definitely review the youtube video by Michael Salven that Roelef suggested.
