Old 10-20-2005, 12:40 AM   #1
Default long fuel line?
ok i seen some photos with the fuel line being long and they wrap it around the tank? does that go to the tank to the crab or tank to the pipe? does it help it any way?
hybrid_eg6 is offline   Reply With Quote
Old 10-20-2005, 02:07 AM   #2
well if its from the tank to the carb, a longer fuel line will give you a little more run time and it will keep the engine running while the car is upside down. If its from the tank to the pipe, a longer fuel line will give a more consistant pressure to the fuel tank. a shorter line will make the pressure a little erratic. Also remember though that too long is not good either.
Genius is offline   Reply With Quote
fuel line/zip tie? ollie 45 Nitro Off-Road 6 10-28-2007 03:32 PM
Fuel Lines... Short-Long What's the difference? MarkieMark231 Electric Off-Road 9 06-16-2006 03:17 PM
how long does fuel keep big dog1 Rookie Zone 5 03-01-2005 06:23 PM
Fuel Line Gundam Singapore R/C Racers 4 01-02-2003 10:28 PM
fuel line: how long is too long? maxboost Nitro On-Road 21 10-29-2002 02:17 AM
SEO by vBSEO 3.5.0
