radio probs
radio probs
I have a futaba 3pdf radio and it has distance problems only will go about 150 feet. any ideas what may be the cause.
Talking of radio problems, my servos are having trouble moving the tyres and throttle. Put some foam backing on the receiver, made sure the crystal wasn't lose but still struggling. Help!
Now to answer your question, check the transmitter's AND receivers batteries, make sure BOTH crystals are firmly in and not damaged and check that you extened the aerial on the transmitter.
tried a freinds transmitter with my crystals and it worked fine, must be in transmitter.
i have my M8 for over 5yrs now and never have that kind of problem.......and i always taking care of my stuff
This is sort of not related, but some ratio equipment is very susceptible to vibrations, as I found out today when my car decided to kangaroo and steer left and right erratically when it shifted into 2nd. completely puzzled by this I started to diagnose the problem. guess what it was, it was caused by an unbalanced wheel of all things! it vibrated so much so when the car went into 2nd gear the rx would malfunction and throw out incorrect signals to the servos, no loose external wires just an rx that hated being shuck around!!
and they say solid state electronics is completely shock resistant, yeah right!
I bet when I take it apart I find a dry solder joint or somethin
Slotmachine
What do they calibrate and where is this getting done?
Dishy
Dishy
