Old 10-01-2005, 03:19 PM   #1
Default Engine wont start problem
Yesterday, I started my engine (using a starter box), it idled for 5 seconds, and then died. Now everytime i try to use it it will start up with the glow plug ignitor but die as soon as I take it off. Thinking i had flooded it, I did the unflood procedure and tryed again later, but this didnt work.
What could be the problem?
wixy is offline   Reply With Quote
Old 10-01-2005, 06:45 PM   #2
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Engine broken in yet? A new glowplug will solve your problem.
Team Duratrax is offline   Reply With Quote
Old 10-03-2005, 03:53 AM   #3
Default Bad Luck
I hate it when that happens, three things to check:
1. The Glow Plug is still firing
2. Your Carburetor settings are correct... adjust the idle screw!
3. Your fuel filter is clogged, CLEAN IT!
theBUZZ is offline   Reply With Quote
Old 10-03-2005, 05:29 AM   #4
Dynamite's Avatar
Send a message via MSN to Dynamite
usually the simplist problem... what theBUZZ says is usually a good start
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
ENGINE WONT START??? Roadrash730 Onroad Nitro Engine Zone 3 01-28-2008 09:47 AM
Engine wont start help! Hpimichael Nitro On-Road 5 03-01-2007 10:03 PM
Engine wont start...need help !! thank you alexlai50 Nitro On-Road 8 11-11-2005 08:18 AM
trx pro. 15 engine wont start, need help... 72skylinegs Onroad Nitro Engine Zone 2 10-09-2005 12:44 AM
Engine wont start dvargas Nitro On-Road 1 04-26-2003 10:17 PM
SEO by vBSEO 3.5.0
