Os .18tz .. Mod?
I would go for it unless you can fit a bigger setup
A mod .18TZ set a speed record for 1/10 scale onroad a few years ago for the ISC. Good choice for bashing should be really fast. I put one in a Kyosho V1RRR it was ballistic!! You may want to consider getting some 40mm wide rear tires for traction you can get them from rc market.
Yes , it had the rpms to match the gearing. For traction and to compensate for the torque I put the 40mm wide rear tires on.
he is a picture of my V-RRR
...........It was fast with the stock gearing. Click onto this link for the tires http://rcmarket.com.hk/product_info....oducts_id=9059
