Old 01-23-2015, 04:50 AM   #31
Originally Posted by nitrohead5300 View Post
illmactic, it is a FG Sportline 4wd.
How much that run you? Like over 1k I'm guessing. Owning one is my ultimate goal in life lmao
illmatic94 is offline   Reply With Quote
Old 01-23-2015, 05:43 AM   #32
I payed $1200.00 dollars for 3 years ago. Very low maintance.
nitrohead5300 is offline   Reply With Quote
Old 01-23-2015, 09:35 AM   #33
Does it have any speed to it?
Old 01-23-2015, 10:19 AM   #34
Yup.
Old 01-23-2015, 10:51 AM   #35
Yup.
What kinda fuel does it run
Old 01-23-2015, 07:04 PM   #36
Gas with 2 cycle oil mixed in it.
Old 01-24-2015, 04:46 AM   #37
Not to mislead you for drag racing, a 1/5 scale is gonna cost you some money. To match the speed you could get out of a 1/10 scale drag car you would need a highly modified 2 cycle motor or even a inline twin , you are looking at about $600.00- $1200.00 dollars right there then you will need custom gears made, very expensive plus custom tires. I would not recommend 1/5 scale for drag racing unless you have bottom less pockets.
Old 01-26-2015, 11:26 AM   #38
Heres my HPI RS4-3 with an OS 18tz modded... great engine!!
Car-Boy is offline   Reply With Quote
Old 01-26-2015, 01:21 PM   #39
Have you ran it yet? Who modded it
Old 01-27-2015, 09:51 AM   #40
Car boy what header you using with that ercm pipe? is it a small block or the big block ERCM pipe? I have the .18tz also to go on a 748 natrix
lighttravler is offline   Reply With Quote
Old 02-01-2015, 11:09 AM   #41
Old 02-03-2015, 06:34 AM   #42
Old 02-07-2015, 12:00 PM   #43
Oso787's Avatar
The best modification you can do to a 18TZ in open the carburator a little to allow more air and in turn, more fuel. I have been doing it for a while in drag racing with outstanding results. Another option, although hard to find, is to replace the carburator with a Rossi Pixy .12 carburator. It is a direct fit and there is no need for the OS carb insert.
Oso787 is offline   Reply With Quote
Old 02-20-2015, 09:11 AM   #44
Why go small when you could put a .21 size carb in it??
Old 02-21-2015, 12:17 PM   #45
What .21 carb you would use on a mod 18tz
