Old 01-11-2015, 02:16 PM   #1
NCG
Default OS MAX 15CV
Hello,
What is the best nitro Fuel % for my engine, OS MAX 15CV? Do you think better 15% or 20% or no problem use 25%?
Thanks,
Best Regards
NCG is offline   Reply With Quote
Old 01-11-2015, 03:17 PM   #2
i only ran 20% on the 5 runs i got out of it but it was used and beat to hell and conecting rod and piston both broke. 20% will be fine idk about 25% but it should be. if its the engine im thinking of isnt it rated for 20-30%
stampede 2wd hobbyking x car 120a esc, neewer 550 4 pole 4300kv motor,turnigy nano tech shorty 2s lipo 4200mah 65c, random crappy rtr controller,soon to be turnigy 15.5kg/cm .16s servo-brushless tmaxx turnigy 160a sensorless esc, turnigy 4 pole 1/8 scale 2100kv motor, some brand lipo from hobbyking 4s 4000mah 30-40c, turnigy 12.5kg/cm servo same controller and receiver, brushless emaxx tranny, hpi sprint 69 mustang body
rc car freak is offline   Reply With Quote
Old 01-13-2015, 03:02 PM   #3
NCG
Hello,
I think the manual says at least 18% oil and nitro 10% to 20%.
The nitro % is easy to identify at the Fuel bottle, where to find the oil %?
Despite the manual, is it possible to use 25% without damage the engine? The Engine have more a less 10 years old, but I only made in MAX 15 tanks, I disassemble it and everything looks fine, put a lot of after run oil and assemble everything again.
This is the motor:
Best Regards
Old 01-13-2015, 03:57 PM   #4
I have both the .12 and .15 if you'd be interested in buying them
Giant655 is offline   Reply With Quote
SEO by vBSEO 3.5.0
