Old 01-19-2015, 04:53 AM   #46
SERPENT CURACAO's Avatar
Send a message via MSN to SERPENT CURACAO
IGT8 is better car more stable then the serpent and easy on the tires .
the IGT8 you dont have to buy the hard springs. only thing you may need is the hop up suspension blocks thats it. www.igt8.com
IGT8
NOVAROSSI ENGINES
MAXY'S FUEL
MAXY'S MODIFIED ENGINE
SERPENT CURACAO is offline   Reply With Quote
Old 01-19-2015, 05:45 AM   #47
swerv's Avatar
When you say hop up suspension block, are you referring to the suspension bracket inserts or the CNC suspension holder set?
insane in the membrane for nitro methane ......
swerv is offline   Reply With Quote
Old 01-19-2015, 06:45 AM   #48
alfonso's Avatar
Originally Posted by swerv View Post
When you say hop up suspension block, are you referring to the suspension bracket inserts or the CMC suspension holder set?
http://www.igt8.com/CNC-10-Degree-C-...-GT_p_110.html
this is the part... is going to give you more corner speed going (in) the turns, more for hi traction tracks.
alfonso is offline   Reply With Quote
Old 01-19-2015, 07:37 AM   #49
Pit-racer's Avatar
Originally Posted by bcquick View Post
Swerv
if your interested in a serpent with all upgrades
pro brakes alum center diff mount, 0 deg steering hubs, 0 deg casterr blocks
hard springs all the optional toe plates
Cars has been raced at nationals Qualified 3rd
and will race this weekend at the pan american race at homestead.
and thats it only two races on it.
send me a pm $350 roller 450 with servos and 550 with maxy mod engine rtr
minus radio and transponder
Sent you a pm if Swerv is not interested.
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 01-20-2015, 08:42 AM   #50
I am looking to get my first GT on road vehicle.....I'm looking for a good quality durable yet fast vehicle....which is the most complete vehicle of the 3? Looking to do some bashing but more race orientated.......I've heard a lot of negative things about the x3 GT.....just trying to figure out which car is for me,I haven't heard too much about the IGT8.....less wrenching and more driving would be awesome.....Help me out fellas,lead me in the right direction please.....A owners opinion of these vehicles would be a plus for me...... Thanks in advance....
swerv:
This should help in your decision making process:
Pan Am 1/8 GT Grand Prix, Jan. 16-18, 2015
Good luck.
www.rctarget.com and www.igt8.com team race engineer and M.E.S.H. specialist. Poor driving skils tho!!!
Cayo71 is offline   Reply With Quote
Old 01-20-2015, 11:58 AM   #51
swerv's Avatar
[QUOTE=Cayo71;137raclsswerv:
[url]http://www.rctech.net/forum/nitro-road/842377-pan-am-1-8-gt-grand-prix-jan-16-18-2015-a-4.html[/url]
Good luck.[/
Are these guys using off road or on road engines in races like this ?
Old 01-20-2015, 12:30 PM   #52
alfonso's Avatar
[QUOTE=swerv;13794958]
[url
Good luck.[/
most of the people uses on road engines, of course.. Picco an Novarossi are the dominant brands. But yes, off road engines can be used to
Old 01-20-2015, 01:06 PM   #53
cnc suspension holder set that is what i mean.
IGT8
NOVAROSSI ENGINES
MAXY'S FUEL
Old 01-21-2015, 01:46 AM   #54
swerv's Avatar
I take it this does not come In the IGT8 PRO KIT........ Does this have something to do with the handling characteristics of the car,and how it sits squats & rolls ?
Old 01-21-2015, 06:14 AM   #55
alfonso's Avatar
No, they do not come in the kit. Yes, are used for fine tune the suspension...
The car that won the homestead race in sportsman class, and the second place in Pro class, use the factory location suspension holders.
Old 01-21-2015, 08:21 AM   #56
IGT8's Avatar
Originally Posted by jmoneym View Post
IGt8 is a owner just rebadging the X3.
Thanks Jermaine,
IGT8 does a lot more than rebranding an X3 GT and the differences are as follows:
Different Internal Ratio
Different pinion gears
Double brake system with metal discs and pads
150cc. Fuel Tank
Lower Engine mount
Chassis Roll Bar
4 Shoe GT Clutch and clutch bell assembly
Carbon Fiber Battery and Receiver covers
And to be released "The IGT8 Pro 2015 version"
Harder Servo Saver Spring
Rear CVD and Aluminum Insert for rear bulkhead
Bearings for servo saver shafts and brake levers.
Wider front wheel hexes
All this in a kit version for the racer to build.
X3 GT and IGT8 might share the same geometry but at the same time a lot of changes have been made to consider them the same car. Not to mention full support national and international at any of the main GT events from the factory and distributors located in all Central and South America.
IGT8 is making GT racing more affordable without sacrificing performance and durability and is proving to be the best product right out of the box intended for serious racers looking to perform at their best on this fast growing class.
IGT8.com
One Stop for all your GT needs !!
IGT8 is offline   Reply With Quote
Old 01-21-2015, 08:43 AM   #57
swerv's Avatar
Originally Posted by IGT8 View Post
Thanks Jermaine,
150cc. Fuel Tank
Lower Engine mount
Chassis Roll Bar
Will this kit contain the 10 degrees C hubs & the said suspension holder set that was mentioned earlier ? Any ideals on how soon this kid will be coming out ? Will a hardworking average Joe be able to afford this new racer version of the IGT8 ???
Old 01-21-2015, 09:38 AM   #58
IGT8's Avatar
Those are optional items that are not needed and are used as a tuning option, in fact most drivers with the optional suspension blocks ended up using them in the stock position. The 10 degree C hubs used by some of the racers was more a driver preference to fit their driving style. We recommend starting with the stock setup as most drivers have give us great feedback from it.
The 2015 version should be announced by the end of this week.
IGT8.com
Old 01-21-2015, 10:30 AM   #59
Pit-racer's Avatar
Are any of these IGT8 drivers racing at the GLARCRC Airtronics race in Calif. in a few weeks? Would like to see one in an average Joe hands.
Old 01-21-2015, 11:17 AM   #60
swerv's Avatar
Me too especially mine
