Old 01-01-2015, 05:42 PM   #1
Default mtx5 modification
Was wondering if anyone knows if the lay shaft bulkheads from mtx6 fit the mtx5 I would hate to spend all that money on a new car
robert161978 is offline   Reply With Quote
Old 01-02-2015, 08:24 AM   #2
DS Motorsport's Avatar
The center to center distance for chassis mounting holes is 14,50mm.
But you will need a lot more parts to upgrade to MTX-6 specs?.
By just replacing the 2 speed bulkheads you won't cure the MTX-5 problems.
Isn't it better to sell your MTX-5 and buy a new MTX-6?.
I think this costs the same as upgrading, might be even cheaper.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 01-02-2015, 08:47 AM   #3
choisan's Avatar
True, a 6 is selling about $5xx in Taiwan, a 5 should be sold for $2xx.
It's not worth to upgrade it that way
choisan is offline   Reply With Quote
Old 01-02-2015, 11:41 AM   #4
Default mtx5
Hey thanks just wondering funds are Lil tight and I didn't know if it was cheaper to try to cure the mtx5 which I never have had stripped gears yet but pretty sure it will happen
Old 01-02-2015, 11:59 AM   #5
Default mtx5
my plan was using the lay shaft bulk heads and trimming them and using that carbon fiber brace on mtx6 on mtx5 and hopefully problem solved
Old 01-02-2015, 03:21 PM   #6
Send a message via Yahoo to motojon
There is an aftermarket stiffener for the MTX5 to reduce the gear stripping but also if u get the shock towers, and new springs for the 6 and put them on the 5, helps out a bunch in handling
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 01-02-2015, 03:45 PM   #7
NITTO550's Avatar
The knack brace was the answer and still is the answer in terms of the gear problem of the 5 , but there is more to the 6 than just being the answer to the gear stripping problem. I have both , and I don't regret stepping up to the 6. . Now back to the 5, it's kind of a hassle to order the brace but if someone is tight on money and can't upgrade then yes get that brace
There are only two ways to do things. The wrong way or my way!
Rich D..
~Mugen Seiki Racing MTX-6 ~,
Novarossi racing Engines ~Ko Propo, ~Avid Bearings..
VBC Racing Wildfire D07 ~LRP Electronics ~ Fantom Racing
NITTO550 is offline   Reply With Quote
Old 01-02-2015, 09:35 PM   #8
Default mtx5
Do you know where I can aquire this knack brace
Old 01-02-2015, 09:36 PM   #9
Default mtx6
Was also wondering what differences between the 5 and 6 that make the 6 alot better other than the gear stripping cause they look the same to me
Old 01-02-2015, 11:12 PM   #10
bigbank66's Avatar
The knack is the best brace out there by far...if that is the only problem u r having knack is your best bet....but check the breaks because stiffening the chassis put more stress on the break parts...an then make the set up ajustments for a stiff rear end!!!
bigbank66 is offline   Reply With Quote
Old 01-03-2015, 12:15 AM   #11
bmain57's Avatar
The new shock towers and springs are the biggest difference you will find between the 6 and 5. The new springs are progressive and the shock towers are shorter. To setup ride height you don't have reload the spring to get the correct height. By doing this the car has a softer feel to it which seems to help the car roll in the corners unlike the 5 which was a very stiff car.
THANKS TO ALL MY SPONSORS...
MUGEN SIEKI USA, NOVAROSSI, KO PROPO AMERICA, PROTOFORM, AVID, FLASHPOINT FUEL AND TIRES.
bmain57 is offline   Reply With Quote
Old 01-03-2015, 04:49 AM   #12
choisan's Avatar
You can order from Pro futaba in Japan. With that said, ordering just one item is not justified.
Simply look out from online store
Old 01-03-2015, 04:55 AM   #13
NITTO550's Avatar
Google air knack racing. But as choisan mentioned pro futaba shop has a whole lot more things to buy.
Rich D..
Old 01-08-2015, 12:05 AM   #14
Default about mtx5 and mtx6
Much better to buy a mtx6 than to upgrade your mtx5. Before I've been thinking to buy mtx5, but I bought this mtx6 than to upgrade and it cost more than bucks to upgrade a mtx5.
chitoschumi is offline   Reply With Quote
Old 01-09-2015, 10:59 AM   #15
Default mtx5 mod
Ok so here is the news I just got my knack brace and man does it do wonders the chassis is stiff upon braking as far as gears go I did find updated gears for mtx5 this new plastic material which I think the gears off mtx6 might work but gonna
put those in anyways and realign engine and install gears and see how it goes. So far my investment cost me about 60 bucks for upgrades.
