Old 12-31-2014, 06:15 AM   #1
nyamuk's Avatar
Default chassis bent
Hi,
Is it normal chassis to bent after few run or race? My chassis seem to have slightly bent in the middle about few mm when put it backward on flat glass surface.
Some people is it because of heat and flex.
nyamuk is offline   Reply With Quote
Old 12-31-2014, 07:08 AM   #2
Trader Rating: 23 (100%+)
No it isn't normal. My Serpent 747 did almost 2 seasons of racing and the chassis is still perfectly flat. The only time I've ever bent a chassis was on an 1/8th scale car where I crashed heavily at high speed.
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 12-31-2014, 09:52 AM   #3
1/8 IC Fan's Avatar
Trader Rating: 38 (100%+)
What chassis are you running, if its a 1/8 or 1/10 (200mm) Nitro car that is highly unlikely without a wreck. Those chassis usually run between 4-5 mm in thickness. Even wheen heated it takes a lot of heat to yield the material to bend - these engines do not generate that heat. Perhaps one of those cheaper himoto, redcat cars even a nitro RS4 have a higher chance of bending as those chassi are not as strong or thick. Yet even then it takes a wreck to do that. Was your chassis used or tweaked perhaps when you had gotten it, did you check it before assembling the chassis?
-if you can't get ahold of me I am probably working, and that's out in the ocean. So please have patience when trying to correspond. - Thank you.
--->When in doubt try the Search Tab, it can and actually will lead to an Answer!
1/8 IC Fan is offline   Reply With Quote
Old 12-31-2014, 12:00 PM   #4
bigbank66's Avatar
Originally Posted by nyamuk View Post
Hi,
If u r running the mtx5. Yes it's normal... but not a good thing..the 5 has been known to bend because of the break an the flex in the chassis
bigbank66 is offline   Reply With Quote
Old 12-31-2014, 04:59 PM   #5
nyamuk's Avatar
Im running nt1 xray.
Old 01-02-2015, 10:14 PM   #6
nyamuk's Avatar
hi anyone else have same experiance?
Old 01-02-2015, 11:04 PM   #7
bigbank66's Avatar
Thats not good..ran nt1 for over 2 seasons an never bent a chassis...an i took some nasty crashes...check into this bigtime!!.
Old 01-03-2015, 01:04 PM   #8
As long as i`m driving 200mm class, with the Serpent 710, 720, KM H-K1, Capricorn C01 and Serpent 748. The chassis will bend in about a couple of months of driving. Always in the middle of the chassis down, about 1 a 2 mm, its normal.
Cars with stiffner between middle and rear section has less bending, cars without have more bending of the chassis.
In the Netherlands all the topdrivers change chassis plate about 2 a 3 times a year.
At the rear the chassis will wear at the rear bottom end due to bottoming out during acceleration with small tires.
Its not a real big problem as long as the chassis doesn`t twists.
I think it is really strange people say they dont have this, i think this is only to make a brand look better then it is.
rbakker is offline   Reply With Quote
Old 01-03-2015, 02:09 PM   #9
bigbank66's Avatar
Cars with stiffner between middle and rear section has less bending, cars without have less bending of the chassis.
I agree on one thing...if Where u race has the grip u will bend your chassis but Where I race the grip is Med to low an the cars slide more than grip...so a bent chassis is far an few between...not to say one is better than another!!! An to his point after a few races an the chassis is bent an there haven't been a Big crash....it's a problem somewhere..an That's wit any brand...
Old 01-03-2015, 02:26 PM   #10
It has nothing t do with what you are saying, it has to do with simple mechanics.
The way the cars are designed, the forces introduced in the chassis by the braking system (servo to brake cam) and the pulling force of the side belt. Both give a torque moment in the chassis that makes it bend, next to that the rear wears due to contact with the tarmac.
Just put your blocks when adjusting the downstops under both axles fr+rr during setup and you will be ok,
when you start driving al your laps within 0.2s. then its time to change the chassis once in a while.
Old 01-04-2015, 04:42 AM   #11
type of starter box will effect too
kyosho malaysia is offline   Reply With Quote
Old 01-04-2015, 04:47 AM   #12
JamesHealey's Avatar
Is your throttle servo pulling too hard and bending the chassis???
Bending an Xray NT1 chassis is bloody hard work, unless you've hit something hard!
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 01-04-2015, 04:52 AM   #13
blis's Avatar
Our Cap chassis bends also and I agree with the above, the aluminium is also a heat sink for the engine, add continual stresses and it bends slightly, and no we havent hit anything hard. When a couple of mm deviation to a chassis plate makes the difference, then I too will change ours.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 01-04-2015, 08:18 AM   #14
RH93's Avatar
This is Roy trying to fix his bent chassis on his Serpent 748..
Capricornrc
Maxima Fuel
RH93 is offline   Reply With Quote
Old 01-04-2015, 08:34 AM   #15
DS Motorsport's Avatar
And this is what happens when you're being a "Kruidenier" and try to bend it back again:
Credits go to "rbakker"
P1-RC.com
DS Motorsport is offline   Reply With Quote
