Old 12-23-2014, 08:16 PM   #1
Bundy_Bear's Avatar
Default After Run Fuel... what is it?
Noticed this is getting more and more popular and curious as to what it is exactly. I read to is just methanol and castor oil. Methanol attracts moisture so isn't this the opposite to what you want to achieve?
Bundy_Bear is offline   Reply With Quote
Old 12-23-2014, 11:48 PM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
Castor oil is a bit sticky and does not attrac moisture, it will create a perfect airtight seal on the metal parts.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 12-24-2014, 03:29 AM   #3
Bundy_Bear's Avatar
Roleof:
Thanks for reply, do you think any difference between this method and burning fuel out and adding aro and giving it a bump on starter box to move it around motor?
Old 12-24-2014, 04:03 AM   #4
Roelof's Avatar
Basicly no, but....
Castor has a negative thing that it will dry out. It can block the needles and lock the piston if it is not used for a long time. A good afterrun is made of an oil that will not dry out.
Old 12-24-2014, 04:33 AM   #5
blis's Avatar
Andrew, NitroMethane (CH3NO2) is also 02 rich, it's an oxidiser itself. So while many point out the hydroscopic nature of methanol that forms rust (oxide), the Nitro itself will too.
Hugs to Abby and a very merry xmas and new year to you.. and you too Roelof!
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 12-24-2014, 05:40 AM   #6
i use auto transmission oil,it contain with anti-oxidant additive and mineral based not easy to dry off
kyosho malaysia is offline   Reply With Quote
Old 12-24-2014, 06:11 AM   #7
Suspended
all of the after run oils I've bought all are colorless and odorless. which makes me wonder if it's simply mineral oil.
mtpocketsracing is offline   Reply With Quote
Old 12-24-2014, 06:42 AM   #8
blis's Avatar
Bundy was referring to After Run "FUEL" not just After Run, I use a gear oil. As long as it doesnt rreact with the fuel, with and without combustion, you should be fine to use any inert oil.
Old 12-24-2014, 07:43 AM   #9
Geezatec's Avatar
ARF!! If contains Nitromethane, why use it? Nitromethane is still caustic. Father use ARO. Marvel Mystery Oil(MMO) or Auto Transmission oil. ATO considered a detergent oil. Pint of it should last 15-20 years.
Geezatec is offline   Reply With Quote
Old 12-24-2014, 09:47 AM   #10
I totally agree, keep it simple man your over thinking it. Ive use automati c transmission fluid for years. For season end storage, I do take engines apart and clean and dry with isopropyl alcohol, then oil eveything.☺
1fastmxcn is offline   Reply With Quote
Old 12-24-2014, 10:45 AM   #11
Roelof's Avatar
And this subject starts all over again as with many topics on this forum about afterrun.
The question was not what everyone is using but what is the difference between an afterrun fuel based on castor oil or an afterrun oil.
Old 12-24-2014, 01:59 PM   #12
Bundy_Bear's Avatar
Hi Harry
Merry Christmas
I don't believe after run fuel contains any nitro.
Old 12-24-2014, 02:00 PM   #13
Bundy_Bear's Avatar
Basicly no, but....
Roelof
Thank you, sorry for causing more debate about aro and Merry Christmas.
Andrew
Old 12-24-2014, 02:54 PM   #14
blis's Avatar
Originally Posted by Bundy_Bear View Post
Hi Harry
Merry Christmas
Yep brother, that's why some ppl use after run fuel to flush all the nitro out
Old 12-24-2014, 05:40 PM   #15
Lapper's Avatar
Trader Rating: 68 (100%+)
Save yourself some money and just get Marvel Mystery oil. Same stuff
LOSI 8IGHT-E 2.0
TEKIN RX8 Trinity D8 1950
Spektrum DX3S/SR3500 JR 8711
X-Ray NT1, Losi XXX-SCB/Micro T, CRC GenXL, Blade 120SR
If everything is under control, you are going too slow- Mario Andretti
Lapper is offline   Reply With Quote
