Old 12-10-2014, 12:45 AM   #1
Post help me choice a rim for my MOTONICA P81 RS3
i want to buy 2 sets rims for my new P81 RS,they are two different choices,one is light rim like picture one,another is carbon rim like picture two,which one you think is better?
Jusitick is offline   Reply With Quote
Old 12-10-2014, 08:41 PM   #2
Trader Rating: 23 (100%+)
The light rims tend to be quite fragile so if you crash or hit the curbs a lot you risk breaking the rim and trashing the tyre. The carbon rim is harder than the light weight plastic and should be more durable. You'd be better of with standard weight plastic rims if you can get them if you are relatively new to the sport.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 12-10-2014, 08:58 PM   #3
1/8 IC Fan's Avatar
Trader Rating: 42 (100%+)
+1 on what dan stated, the light rims are great if you dont crash much. Yet for as apealing as it is to have light rims, you are always safe with standard wheels.
-if you can't get ahold of me I am probably working, and that's out in the ocean. So please have patience when trying to correspond. - Thank you.
--->When in doubt try the Search Tab, it can and actually will lead to an Answer!
1/8 IC Fan is offline   Reply With Quote
Old 12-11-2014, 12:14 AM   #4
Thank you Dan
Old 12-11-2014, 12:16 AM   #5
Thank you ,so which shore should i use,i pan choice 35°for front rim,and 37° for rear rim.
Old 12-11-2014, 10:50 AM   #6
g-wan's Avatar
Send a message via MSN to g-wan Send a message via Yahoo to g-wan
for me depend on the track surface, but most of the time im using 32 front n 35 rear for qualifing n final using 35 front n 37 rear,
km k8 / os speed / savox / blitz / contact tyre
km hk1 evo / os speed / savox / sweep
sworkz evo / spower evo s7 / sweep / savox
xray t3 2012 / tekin rs pro / reedy / savox
km racing / sworkz / xray / savox / sanwa / os speed / sweep / ulti / blitz
g-wan is offline   Reply With Quote
Old 12-11-2014, 10:40 PM   #7
yes,that's a common choice,and our club have a race this weekend,i will take my MOOTNICA P81 RS there.by the way ,i want use savox 1256 servo on the car,is that ok?
Old 12-12-2014, 12:18 AM   #8
That servo is fine. If you run a lipo receiver pack then run the high voltage version which is 1267/1268.
Old 12-12-2014, 12:44 AM   #9
Roelof's Avatar
Send a message via ICQ to Roelof
That is a slow servo (0.15sec), you can better use the 1257 (0.07 sec) or the 1258 (0.08sec)
Regarding tires, you can use every brand tire as long it has the OS2 measurement, you do not have to use specific Motonica tires.
And maybe it is wise to tell you have bought the electric version?
which motor should i use for my motonica P81 RS3
I also do think it is better to keep all your questions about this car in one topic.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 12-12-2014, 12:55 AM   #10
I think he has both. The GP and EP versions.
Old 12-13-2014, 01:28 AM   #11
Fred_turbo's Avatar
Default i like the EP versions
maybe,but i like the EP versions better,by the way just you can choice the carbon rim if you not for the race.
and where did you get the car,there are no local seller here in Indonesia。
JUST BUY WITH FUNS,PLAY FOR FUN!
Fred_turbo is offline   Reply With Quote
Old 12-26-2014, 10:04 PM   #12
vivi_gao's Avatar
Default i will choice the light rim
in our club 80% people use light rim.
vivi_gao is offline   Reply With Quote
Tags
motonica p81rs3
