Closed Thread
Old 12-02-2014, 08:57 PM   #1
Default Mugen Seiki Mtx-6
Any more issues about mugen mtx-6?
chitoschumi is offline
Old 12-02-2014, 11:26 PM   #2
gotmotor's Avatar
What issues are you having
RcTarget~Airtronics~VP Fuel~Maxpower~SRC
gotmotor is offline
Old 12-03-2014, 01:03 AM   #3
bigbank66's Avatar
Default problems free!!!
Been racing the 6 for about 6 months wit no issues...im not saying the car is perfect but i havent had any problems!!!
bigbank66 is offline
Old 12-03-2014, 12:17 PM   #4
Sometimes my mtx6 will spin in almost every turn of the track I already set-up my car but I don't get it to make it more stable.
Old 12-03-2014, 12:21 PM   #5
Trader Rating: 22 (100%+)
Are you experienced in the class?? If it's spinning at every corner sounds to me to be a serious tweak/setup issue. Usually the stock setup is adequate to at least get the car round. I would go back to square one and check the car again to make sure you've built it right and set it up again using a proper setup station. Tweak out the car properly as well.
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline
Old 12-03-2014, 02:16 PM   #6
yes I do have a experience. Before I bought my mugen mtx 6 my car before was kyosho v one rrr. And this car run's stable and it never spin. I know about this mtx6 maybe the steering it's too sensitive or what?! I already set-up my car again with my set up station.
Old 12-03-2014, 02:24 PM   #7
What i'm having is the car it's too sensitive! even I set it up with my set up station.
Old 12-03-2014, 03:29 PM   #8
DS Motorsport's Avatar
You can do a couple of things to make it less sensitive:
-Move the sliding weight to the front
-Bodyshell mounted more rearward (13-14mm from the bumper) plus rear wing more rearward
-Softer rear ARB
-More toe in at the rear
-Ackerman rearward
P1-RC.com
DS Motorsport is offline
Old 12-03-2014, 06:22 PM   #9
-Softer rear ARB
-Ackerman rearward
I put my sliding weight to 40 and just what I thought about the toe-in rear needs more toe.
Old 12-04-2014, 11:11 AM   #10
bigbank66's Avatar
Default rear traction problems??
With the stock set up...if the traction is low at your track...the rear will be loose....u can try 2.things...drop rear diff oil to 40 or 30..an give the Car more rear toe..u will be able to nail the throttle an the Car will go straight..
Old 12-04-2014, 01:07 PM   #11
You're right bigbank66 our track is low traction and I used rear diff. 50 i'm gonna set my rear toe 3.5 or 4.
Old 12-04-2014, 05:09 PM   #12
choisan's Avatar
There is a thread originally for mtx6.
Having too many different threads will not help.
Moderator, please kindly rectify
choisan is offline
Old 12-04-2014, 07:20 PM   #13
bigbank66's Avatar
If u need more....u might want to drop your roll center...rear arms all the question down...
Old 12-04-2014, 07:21 PM   #14
bigbank66's Avatar
+1
Old 12-04-2014, 08:48 PM   #15
Now i'm done setting-up my mtx6. This coming saturday i'm gonna test this car so that I will know if I made the correct settings.
Closed Thread
SEO by vBSEO 3.5.0
