Old 11-18-2014, 02:42 AM   #1
Default hpi rs4 evo 3 clutch engaging at low idle.
hey everyone, my clutch is engaging at very low idle causing the car to run away, if i put in on the ground, it stalls, does this have anything got to do with the low speed need? anyone know how to fix this problem?
hpirccar is offline   Reply With Quote
Old 11-28-2014, 07:49 PM   #2
MikeGozz's Avatar
Trader Rating: 17 (100%+)
Is it idling properly? Or is the idle speed high?
You probably want to open up the clutch and check the springs to make sure they haven't broken and that they are installed properly.
Do you have a manual for the car?
MikeGozz is offline   Reply With Quote
SEO by vBSEO 3.5.0
