Shepherd Velox V8 "EC" 1/8th Car
#91
The new gearbox with 0,8 module is now available at website rccar24.com
#92
Wish I could get a hold of some pre cut bodies still.
#93
2017 and beyond ?
Anyone knows what Shepherd has plan for 2017 and beyond ? A new complete car or just parts upgrades/updates ?
Come on Shepherd you guys have to stay up to speed with now Mugen and the Infinity 1/8 Nitro On-Road Car. At lest here in the US but am still counting on Shepherd to do something before I start to look at another company.
#94
The major improvements over the previous kit are:
-New smaller + lighter gearbox (uses 0.8 pitch now)
-Rear bulkheads changed (composite bushing for the ball bearings of the rear anti-roll bar mounts)
-Side belt tensioner changed
-Few other parts "re-defined"
Current World Champion
Current European Champion
Current ENS Champion
Not sure you would want to much more changed
#95
We do have the new "WC" in stock.
#96
The new "WC" kit just got released last month, this is the 2017 Kit.
#97
#99
#100
#102
A fantastic base setup which has worked very well with our team within the UK, the only error on this setup sheet is the front eccentric hubs should be in the upper notch (axles down).
Just thought i'd share this with guys out there as we never experience very high grip in the UK, so this maybe much more useful than a setup found at Euros/Worlds level grip.
This setup was used to win the BRCA national at Wombwell circuit, a very technical track.
#103
Can someone tell me what the advantage of Shepherd switching to a 8mm two speed shaft opposed to the 6mm shaft? Seems to me it would just add weight right? I am currently running an upgraded titanium 6mm shaft and wondering if there would be any advantage to switching to the larger 8mm steel one and adding about 15 more grams.
#104
Glutton, i dont know the weight of your titanium shaft. You have to remember that the 8mm shaft is hollow and the 2.gear garrier is lighter, so the 8mm shaft is 2 gram lighter if you inklude the gearbox.
#105
Thanks for the info. So it actually creates a little bit of weight savings over the 6mm one then. I can't imagine they switched over to an 8mm shaft for the 2 gram savings tho, so maybe it's just to have a more durable part or something? Just figured there must be some good reason for the 8mm shaft because every car out these days uses one.
