Old 11-05-2014, 11:08 AM   #1
Default Stock needle settings
Hi, I hope this finds you well , my question is what are stock needle settings for HSP 1/10 nitro rc truck .18vx engine ??? Kind Regards
Ala Sarchel is offline   Reply With Quote
Old 11-05-2014, 01:49 PM   #2
Geezatec's Avatar
Out of box engines are flush with needles, and 1.5mm Air gap( throttle opening, idle speed). LSN turn CW till bottom out, then 4 turns CW. 3.5 to save time.
Geezatec is offline   Reply With Quote
Old 11-06-2014, 05:27 AM   #3
Default stock needle settings
thank u for your coopration what about HSN ????
Old 11-06-2014, 08:33 AM   #4
Geezatec's Avatar
Sorry misstated. HSN Flush or 3.5 CCW from closing. LSN Flush. Air gap 1.5mm. Note that this doesn't tune the engine, but it does get it running. Your manual should these starting points.
Old 11-06-2014, 08:46 AM   #5
i checked my manual its says "2 or 2 1/2 turns from fully closed postion" is that for HSN or LSN or Both ???
Old 11-06-2014, 09:38 AM   #6
Geezatec's Avatar
HSN Fine. LSN always depends on location, altitude, Weather. LSN always the last adjustment. Where are you located?
Old 11-06-2014, 09:48 AM   #7
iraq!!!
Old 11-06-2014, 03:07 PM   #8
Geezatec's Avatar
k!
SEO by vBSEO 3.5.0
