Old 10-15-2014, 10:23 AM   #16
gsxr0311's Avatar
Trader Rating: 18 (100%+)
Harold, did you play with the diff height adjustment yet? Where did you run yours high or low? Thanks
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is online now   Reply With Quote
Old 10-15-2014, 04:16 PM   #17
Harold996tt's Avatar
Mate I had it built as per instructions. Let me check again what that was at.
Capricorn C802 1/8 GP, Mugen MGT7 1/8 GT.
Nostalgic collector of old Rc junk.
http://www.tamiyaclub.com/showroom.asp?id=44535
http://vintagerccar.blogspot.sg
Harold996tt is offline   Reply With Quote
Old 11-21-2014, 04:52 AM   #18
dj apolaro's Avatar
Hi Guys,
I built and tested for the first time last weekend the new C802 car. I had only 2 days on the car, but I am really happy so far. For me the new car built very easy compared to the prior car. My only issue was with the brake top part that had to be drilled a little to not have the brake return bind. The rest for me was good. Learning the front end also took me a minute, but is pretty cool looking. I built the car with all the stock parts and only added the heavy battery tray. I used the stock sway bars, shock, pistons, oil, etc.
I ran the car at Kissimmee, Fl which is a higher bite track with some bumps. When I started I could tell right away that the car drove much smoother than the C801, not as twitchy. The car stock did have a little push mid corner. My changes made to help with this was more angle in the rear shocks, went from 60wt to 70 wt shock oil all around. Front mugen white springs and rear Capricorn blue's. I was really happy with the car at this point. There is still a little to gain and I will test more in a couple of weeks. However, for the first time with the car and not much time to make changes I am really happy and think others will be also once they play a little with the set up. It is a smoother drive, but still has steering.
We took the Win in the Forgass State race for the first time out with the car!!!
https://www.facebook.com/capricornamerica
See ya at the track,
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 12-11-2014, 08:22 AM   #19
dj apolaro's Avatar
Here is the set up that I used this past weekend at the Kissimmee track for the Nitro World cup.
Car was easy to drive and pretty fast.
Let me know if you have any questions,
DJ Apolaro
Old 01-20-2015, 02:07 PM   #20
I notice the car comes with the now older style blade type front anti roll bar as standard and no rear radio plate flex items ? Are the rear flex and wire front anti roll bar essential hop ups or is the car fine in standard format?
Also notice there is a front flex system which seems to be top of the servo saver based ? How effective is this ?
8thracer is offline   Reply With Quote
Old 05-02-2015, 01:20 AM   #21
I have just purchased, built and run my new C802 and am quite impressed by the car overall. Some questions I have. What is the effect of swapping the front hubs over so you have the 18mm (+1) on the bottom rather than the top?
When testing on a circuit that has some fast sweeping corners I have some initial on throttle understeer (Push) on the exit of these corners with the standard out of the box setup. (Also have chassis flex locked OFF for now) So have to back off the throttle mid corner to allow the car to rotate better. I have good rotation even leading to a hint of snap oversteer on slow speed tight corners. Therefore which way would the advice be to go on geometry to balance the car a little better for the high speed corners ? Tyres being used are 35 rears 32 fronts trued with a 7mm difference between Front/Rear
Old 05-14-2015, 07:30 AM   #22
dj apolaro's Avatar
Default C802 Starting set up
Hi Guys,
A couple of people have asked for a starting set up for the new C802. This is what I use for myself. I Find this easy to drive and still quick.
If you have an questions just ask and good luck.
DJ Apolaro
Old 10-06-2015, 07:54 AM   #23
pioupiou's Avatar
Something new for the next Wc on the Lab c802?
pioupiou is offline   Reply With Quote
Old 01-02-2016, 12:53 PM   #24
pinoy69racer's Avatar
Trader Rating: 180 (99%+)
HENRY C
DESOTO RACING/SERPENT/VEYTREX DESIGN LAB/RC TARGET
pinoy69racer is offline   Reply With Quote
Old 01-26-2016, 04:16 AM   #25
I have a C802 for sale used for 1 race meet, it has titanium pivot balls and titanium screws. Please pm me and I will send pics and price
snaps5 is offline   Reply With Quote
Old 04-05-2016, 01:58 PM   #26
Default Radiobox and Futaba receiver
Anyone who use a Futaba 614 receiver. If so hov does you fit in the cap Radiobox?
jensroland is offline   Reply With Quote
Old 04-06-2016, 11:23 AM   #27
Fits even with transponder
thilo-alexander is offline   Reply With Quote
Old 04-08-2016, 10:27 AM   #28
Uhmm - Yes.
After fiddling a bit with it I have found a solution
Old 04-18-2016, 01:41 PM   #29
pioupiou's Avatar
One question to the top drivers:
On the 802 the standard steering horn need to be replaced by the c03 steering horn?
Is the length bigger? How many more?
Old 04-18-2016, 01:49 PM   #30
dj apolaro's Avatar
You replace the top part of the servo saver with the C03. YES
It gives the ability to have more degree of steering without binding the steering linkage. It is actually shorter. Still use the adjustable part on the bottom piece.
DJ Apolaro
Tags
balestri, bryson, c801, c802, capricorn
