Old 10-05-2001, 01:06 PM   #1
Cool Turbo Glow Plug Help?
I have been running non-Turbo R/C engines for 10 years, but I have no-clue about the Turdo plugs. I just purchased a Nova-Rossi .12 RE turbo. Could someone help me out with what Turbo Plug I should run?
I live in Texas (as that was not obvious by my handle) where it is hot real hot. With winter coming is there a different plug to run when it is cold or hot outside?
Thanks for any help!
rcTexas is offline   Reply With Quote
Old 10-05-2001, 07:52 PM   #2
che's Avatar
Default Turbo Glow Plug
Taken right from Nova ROssi's website:
Technical specifications of turbo glowplugs
Turbo glowplug was conceived to give to the engine higher performance and it is available in 8 versions: 4 hot and 4 cold.You find here with a description schedule that gives to the drivers the possibility to choose the suitable glowplug according to the situation he is operating.
Type Features Nitro % Increase performance Outside Temp .
C.5 TC Hot with hot filament 10-20% + 10% from 5 to 10
C.6 TC Hot with avg filament 10-20% + 8% from 5 to 20
C.7 TC Hot with cold filament 20-30% + 6% More than 20
C.8 TC Hot with very cold filament 20-30% + 5% More than 20
C.5 TF Cold with hot filament 20-30% + 15% from 10 to 20
C.6 TF Cold with average filament 20-30% + 13% More than 20
C.7 TF Cold with cold filament More than 20% + 12% More than 20
C.8 TF Cold with very cold filament More than 20% + 10% More than 30
Merits and failings of turbo glowplugs
Hot glowplug guarantees a better adjusting of the engine at low RPM while the cold glowplug gives a better performance at high RPM. If you have a cold glowplug on your engine and have difficultes to keep it regular at low RPM, we advise you to make the base speed a little higher. In case the engine goes out again, we advise you to replace the above mentioned glowplug with a cold one; these difficulties in the carburation aren't due to a bad running-in of the engine but to anomalous climatic and meteorological conditions (see high degree of humidity, altitude, low pressure, etc...).
During the installation of a turbo glowplug on the under head verify that no dust or any other material come inside because they could make precarious the seal of this glowplug during the compression.
che is offline   Reply With Quote
turbo glow plug? Ultraspeed84 Nitro Off-Road 1 08-17-2007 05:10 PM
RB GLOW PLUG 2 TURBO 2 STAND. HECTICRACER R/C Items: For Sale/Trade 10 08-06-2007 10:51 AM
OS P3 Turbo Glow Plug Tag R/C Items: For Sale/Trade 1 01-14-2006 11:41 AM
OS P6 Turbo Glow Plug 2 New John Q R/C Items: For Sale/Trade 5 06-15-2004 04:58 PM
Will a standard glow ignitor work on a turbo glow plugs? Ducati998 Nitro On-Road 3 01-19-2003 11:54 PM
SEO by vBSEO 3.5.0
