radio question again..
whats the big difference between the futaba 3pk and the M11, need a radio now i can get my hands on the futaba 3pk today, or should i wait for the M11 to come off back order..
question is if i get the 3pk now, will i be selling myself short? either/or, i was planning on dropping that new spektrum dsm in one or the other..
what should i do?
I was at my LHS today, and he told me that Futaba and Hitec are coming out with their 2.4 Ghz version toward the end of the year.
They will be making full blown 2.4 Ghz radio/receiver kits, as well as offering their own radio module/receiver setup for existing radios.
I've been using my Hitec Lynx 3D w/Spectra module and a Novak XXtra for years, and I love this radio.
Hitec's 2.4 Ghz system is probably going to blow Spektrum away knowing the price point they're going to release it at.
I have to give Hitec the edge on this one. They were the first to come out with a synthesized radio years ago, before anyone really caught on to it, and they pack a lot of performance into their radios for the money.
what should i do?
3PK is excellent choice. Don't think you would be giving anything up compaired to M11. Both are top notch.
they both seem like there the same thing what do you think..
but if futaba comes out with something later in the year i'll be pissed..
I have the 3pk and love it... I was looking through the new features of the m11 and didn't see any that would sway me in the direction to purchace one.
get the 3pk
get the 3pk
Yep, the 3PK is a great radio....the only tiny downpoint i can find with it, is its a bit heavier than some radios.
Cheers
Cheers
Location: The Milkyway/Planet Earth/Europe/Sweden/Skåne/Malmö
Also I love my 3PK, it's main advantage is the large display that makes progamming so much easier. As someone said, it could be a little heavy, but then go and ge yourself a neckstrap (the cheap method) or get a 3-cell LiPoly 11.1 volt battery, a friend on the track uses the last method, and with DSM module (no heavy antenna) and Li-Poly the radio is really light..
Buying it won't dissapoint you..
I beleive the M11 is just as heavy, if not heavier. Helios or JR Z1 is best choice. The very best ergonomics of any radio, all the best features, and has excellent ballance.
Aint the Helios a little hard to navigate/program with that (compared to the 3PK) small display?
Personally I like the 3PK's ergonomics better than the Helios, but thats all personal.
I guess that depends on the LiPo's capacity, but a friend of mine uses this set-up, and he charges it like one time per month, so I guess they give great battery life..
I've looked at a lot of radios and even tried some when I was looking to replace my old trusty JR XR6-FM radio, and ended up with the 3PK. This radio really is fantastic. It feels great, has great balance, an adjustable wheel and easy programming on a very clear display. You can even configure the color of the power LED . And with a pack of 2500mAh NiMH cells it has great run time... Definitely one of the best radios available now. And you can upgrade it with a spectrum unit if you want...
I should have stipulated; WITH the drop-down/adjustable wheel option, it is the most ergonomic radio on the market. That takes into consideration; weight, balance, hand position & finger postion. Having the adjustable angle allows adjustment for different 'girth' of the drivers .
KO has put more engineering effort into the 'fit' of their tx than than the others, but the bottom line is, which one 'feels' right to you!
3pk has a great feel, and should fit well in most peoples hands. One thing for shure, these two radios are first class!
what should i do?
what should i do?
do yourself a favor all the top brands have the same features they just call it something else buy what feels right not look,brand or who uses what you will just end up dissappointed in the end buy what feels good in your hand its all about comfort when your an the stand.
steven
