Old 08-18-2005, 09:33 AM   #1
Default Diff and Shock Fluid
How offten do you have to change the fluid in the Diff and Shocks...
chumanji is offline   Reply With Quote
Old 08-18-2005, 09:00 PM   #2
Chaya's Avatar
differential fluid quality usually deteriorates due to some residue produce from the meshing of your bevel gears. Usually the fluid turns darker in span of time. If you are into racing I guess you have to check it from time to time. but if your not, i think you just have to check whether there are some leakages in your differential and have it filled. Without fluid would worn out your gear easily.
For the shock fluid, I havent replace yet my shock fluid for almost a year. But I just check it regularly for sign of leakages. . .
Hope it helps. . .Cheers!!!
Xray Nt1 l Xray T3'12 l F104PRO
Chaya is offline   Reply With Quote
New "BB" diff and shock fluid!! glassdoctor Nitro Off-Road 6 03-31-2008 12:46 PM
MBX5R shock fluid ManiTouU Nitro Off-Road 1 09-08-2007 05:25 PM
shock fluid for buggy downunder23 Rookie Zone 1 08-07-2006 02:38 AM
Xray shock fluid BiggAlz Electric On-Road 9 01-12-2006 06:17 AM
What shock fluid to run at my track in my FT T4 BSchorr Electric Off-Road 2 06-13-2005 04:34 AM
SEO by vBSEO 3.5.0
