rubber and foam >
rubber and foam
rubber and foam
Old 08-08-2005, 08:12 PM
Default rubber and foam
Hi all,
I have an RRR WC and a G4 C-class. And i am planning to have rrr in foam and the g4 fitted with rubber. Reading from the posts in rctech i read that to fit rubber tyres, front differential is more suitable. With my G4 having a front differential, what other changes do i need to do to my g4 to maximise the use of the rubber tyres.
Tiger
tiger266 is offline
Old 08-08-2005, 09:26 PM
nsxshogun's Avatar
I'm not so sure about this but I think you should lossen up the rear camber. I had some on my r40 and the inside's wore out and eventually tore when I ran some hpi rubbers.
nsxshogun is offline
Old 08-08-2005, 09:59 PM
RJonesJr's Avatar
You definatly do not want to run that much toe in or out because the friction from the tire going against the aspalt will created more heat the more away from zero degrees of toe you have. This will make the tires too hot and wear a lot fast. Not to mention it will make your car slide all over.
RJonesJr is offline
Old 08-09-2005, 07:23 AM
afm
afm's Avatar
Originally Posted by tiger266
Hi all,
Tiger
Tiger
The G4 was British National Champion on 2004 in the Rubber Tyre Class, and this is what Darren Johnson (the Champion) has to say about it.
AFM
Advice on Rubber Tires:
The car is good on rubber tires too!
There are set up sheets on the CML website for G4 on rubbers
http://www.cmldistribution.co.uk/car_setup.php
http://www.cmldistribution.co.uk/cml_setup.htm
I always ran an insert that fills the tire (you don’t want an air gap, not like electric). I like Sorex type-a medium, on a 24mm wheel with the tire of your choice, but always the same grade of tire front and rear.
Darren Johnson
CML Racing Team UK
28-06-05
afm is offline
Old 08-09-2005, 06:43 PM
Originally Posted by afm
Tiger
AFM
Darren Johnson
CML Racing Team UK
28-06-05
Thanks afm.
tiger266 is offline
Old 08-09-2005, 06:47 PM
what works best for parking lots and street racing? Foam, Slicks, or treaded rubber?
cars.cars.cars is offline
Old 08-11-2005, 08:29 AM
Jye
rubber slicks. try the belted slicks from hpi.
Jye is offline
Old 08-11-2005, 03:52 PM
Rapid Roy's Avatar
Make sure you get the "R" compound. 33r's are for hotter weather.
Rapid Roy is offline
