Old 08-10-2005, 09:16 PM   #1
Trader Rating: 12 (93%+)
Default to true or not to true tyres on club days ??
hey guys
just wanted to know if its worth cutting down tyres to a smaller diameter for club days ?
mrgsr is offline   Reply With Quote
Old 08-10-2005, 11:01 PM   #2
soc123_au's Avatar
R/C Tech Charter Subscriber
It all depends on how deep your pockets are. If you can afford it then go for it. The more often you race the car with the same tyre diamater the faster you will become. Personaly I run them out of the box on club days & when they get close to the right diamater I put them away for more important races. That could be why I cant catch the big boys
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 08-11-2005, 12:25 AM   #3
Roger's Avatar
If funds are holding you back from truing your tires at club races, then I would suggest running them without truing them. I usually ran them untrued when I first got into nitro sedan and they worked just fine. But, when I bought a hudy tire truer, I was truing my tires all the time.
Roger is offline   Reply With Quote
Old 08-11-2005, 01:06 AM   #4
I usually true my tires to get the best handling out of the car. You should also consider the fact that tires won't chunk as easily if you true them. If your tires don't chunk then I guess its alright to just run them as is.
Genius is offline   Reply With Quote
Old 08-11-2005, 05:11 AM   #5
tomkelley's Avatar
A car that handles well usually depends on your tires. If the car rolls over on your track then bring it in and cut the tires down some. A broken car is more expensive to fix than replacing your tires.
Detroit Radio Control Car Club
tomkelley is offline   Reply With Quote
True R/C Lipo bprc10T3 Electric Off-Road 10 03-26-2008 06:05 AM
The One True 13.5 Thread syndr0me Electric On-Road 713 02-02-2008 01:53 PM
Is This True???????? Zac R Electric On-Road 24 03-24-2005 08:47 PM
Is this true? doublest Electric On-Road 7 05-14-2003 08:35 AM
Is this true ?????? Brett Australian Racing 9 07-14-2002 01:33 AM
SEO by vBSEO 3.5.0
