Serpent 748 200mm nitro onroad kit
#482
I was referring to those guides you download on the site choosing a certain guy setup. With the sheet already filled out.
#485
New Paint Scheme
Hey guys
I'm trying out a new paint design. Going towards a more graphic approach for the April races in HK. Let me know what you think. I'll post the finished product.
#488
The diffs also need to be checked and probably a rebuild would be advantageous using 19.3gr of oil in each (as per a team driver recommendation).
Rebuild the shocks assuring same pressure in each and same length each. Add the springs and set equal pre-load.
Rebuild the car and setup correctly replacing anything bent in the process. A tweak station is advantageous or use the wheel lifting method however the later is critical on the droop screws being exactly the same left /right.
Then try it on the track and see how you get on.
#489
#490
Do you guys know if the Serpent changed the shock bladders to clear ones on recent batch? I just put Yokomo bladders on my 748 and random Chinese ones on Eryx 3.0 and both work good. No more holding the shock body when turning the shock collars. I'm happy
#491
If you just cut the collar O-Ring in half and just use half the O-Ring in the collar it releases enough friction to allow the collar to be moved without turning the whole shock body.
#492
Part number
Hello
Sorry is you listed the part number before. Can you pls list the part number for the upright with the drilled hole for the stiffener . Thank you
#494
Moreover, cutting the ring still doesn't guarantee that the shock body will not move.
To me a few dollars of investment was definitely worth it and I hope they have made the change. I was just wondering if they have
#495
Glad it works for you Dan but I don't think I can cut the O ring cleanly. And if you cut it in half, wouldn't it be more like you don't use it? Then every time I touch the springs, it might rotate? Or even during the race due to vibration?
