Like Tree14Likes
Old 01-17-2015, 06:40 AM   #406
Originally Posted by lighttravler View Post
Ok nitro so my ? Again is do you think it is fine to run esr 971 in both steering also? Ok kyosho thanks. Which one do you use and does it fit tight.
YES, i `v been running the SANWA ERS-971 on Steering and Throttle for the last year, meaning 12 months. The Sanwa ERS-971 Steering and Throttle servo are powered by my life zippy 700 battery for the last year. Next to that the Reedy Life battery is used on the Steering and Throttle Sanwa ERS-971.
At my local club at least 5 people drive the same combination, but i have to say, that the guy thats the fastest uses the sanwa srg-bls version 2 on steering and throttle, so if you really want buy those..
rbakker is offline   Reply With Quote
Old 01-18-2015, 11:11 PM   #407
Thanks for your help. Now I will order servos and life packs
lighttravler is offline   Reply With Quote
Old 01-20-2015, 12:44 PM   #408
NP, great, so what did you end up buying?
Old 01-20-2015, 08:09 PM   #409
Ordered 2 zippy the link you sent me. Orderd 2 Sanwa esr-971 throttle and steering. I had to get those from Hong Kong since I live in the states.
Old 01-21-2015, 05:42 PM   #410
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
Originally Posted by lil-bump View Post
With blank rims I set my ride height to .55mm front and 1mm rear. If traction is high I start a little lower maybe .25 and .65 I use automotive feeler gauges for the measurement.
Pass you soon...
Bump. Where are you measuring the ride height in the front?
Nick Altieri
TeamNitro RC Club, New Home track- Ho Chunk Southland Expo, Lynwood IL
Serpent 748 Natrix WC, PICCO EMX "R", Spektrum DX4RPro, Futaba servos
977 EVO2, Matrix tires, Picco power.
Please drive responsibly
TeamCarnage is offline   Reply With Quote
Old 01-21-2015, 05:49 PM   #411
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Nick try right behind the lower arms.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 01-21-2015, 05:53 PM   #412
lil-bump's Avatar
Trader Rating: 83 (100%+)
I remove the front plastic bump and measure @ the very front of the chassis.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 01-21-2015, 07:20 PM   #413
Hey Dan.. That's where I usually measure. The left side is clear. The right side the servo mount is in the way. You'll see when you finish your build. I think Elliots got the right idea. Although I'm going to hate taking the bumper off every time for an adjustment. It's bad enough I have to deal with the spinning shock caps during collar adjustments. Gotta come up with a cure for that. The shocks were so easy to build, I knew their had to be a downside..
You going to the Forgass Race?
Nick Altieri
Old 01-21-2015, 08:16 PM   #414
bighurt98's Avatar
Default TQ diff oils?
What diff oils came in the new TQ car? I heard you need double the thickness in rear. Normal is 300K and 80K. Any difference to start with?
Capricorn C03/Matrix Tires/Novarossi
Capricorn RC USA/RC Target
Murnan Modified Motors
Desoto Racing
Team Gravity
bighurt98 is offline   Reply With Quote
Old 01-21-2015, 08:49 PM   #415
dan_vector's Avatar
Trader Rating: 27 (100%+)
You may want to start with 1 million in the front diff and 150K in the rear diff on the new diffs. At least 600K in the front if you don't have 1 million. Very important that you don't overfill/over tighten the new diffs as well.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-21-2015, 08:55 PM   #416
nitrodude's Avatar
1.000.000 and 100.000
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 01-22-2015, 05:34 AM   #417
We always setup the car with rims without tire on it (grind tal the rubber of), then we use a ride height in the front of 0.5mm and rear 1mm, i never measure and just feel if its ok.
For the shocks, the adjustment collar has a silicone o-ring in it, it has to much friction, just cut it in 3 pieces and only put 1/3 in the collar, now it will rotate smoother.
Old 01-22-2015, 08:13 AM   #418
I hope to be there Nick
Old 01-22-2015, 08:36 AM   #419
I'll try that mod first! Thanks. I have spare shocks to experiment. Don't want to take a chance of the collar backing off on its own during a long main.
Nick Altieri
Old 01-22-2015, 08:47 AM   #420
It does not backoffduring racing, been doing that for a long time and won a lot off races with it.
Start with 3/4, then 1/2, and 1/4 of the o-ring to try..
