Like Tree6Likes
Old 12-27-2014, 07:31 AM   #331
lil-bump's Avatar
Trader Rating: 82 (100%+)
Originally Posted by dan_vector View Post
Yes. Mostly Xceed as it fits the best. I however prefer life and use the reedy pack.
Same here. For club races I use 700 mah li-fe. It will do a half hour main with no problem. For longer races I use reedy 1300 mah li-fe. I would love to get the 1000 mah li-fe (Vapex)that is only sold in the UK.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 12-27-2014, 03:52 PM   #332
MeClown's Avatar
Default Christmas 748 build
Hey guys. Just got a 748 for Christmas ans here is where I am after 2 days of build. I am running into some problems regarding the battery and the throttle set up.
MeClown is offline   Reply With Quote
Old 12-27-2014, 04:46 PM   #333
nitrodude's Avatar
Originally Posted by pinoy69racer View Post
Xceed
Is it the same one as the 977 battery?
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 12-27-2014, 06:22 PM   #334
OldfartWal's Avatar
My TQ should arrive next week, we run 2 classes here for 200mm, 1st (which the new TQ will be) class is Gas Tourer, pretty much std EFRA rules except it's a OS TG (0.0128 cu.in/0.7hp) motor & no INS box, it will be a challenge as there's no hints/tips around for using the lower HP motor.
My current 747 will continue to be the front line race car until we sort the new TQ out, then I'll switch it to Pro Tourer (pretty much EFRA 200mm rules).
Any tips on building the new TQ with an aspect to the lower HP engine would be appreciated, also I'm looking for an earlier 748 roller if anybody has one they're considering selling, that way the old reliable 747's can be retired to spare part supplies.
OldfartWal is offline   Reply With Quote
Old 12-28-2014, 02:46 AM   #335
Trader Rating: 23 (100%+)
Basically yes however there is more room in the 977 and so larger packs will fit in the 977 like the Protek 2200 lipo which doesn't fit in the 748.
Both the xceed lipo and the reedy life fit nicely in the 748.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 12-28-2014, 02:50 AM   #336
To be honest the 748 hasn't really got any vices or issues with the build. Just follow the manual. I don't have any experience in the low HP motor class but I'd probably just start out with the car out of the box but go to 15/21 on the pinions just to give that little engine a chance! Clutch just set it as per the manual - I'm sure you know what you are doing with that from the 747 anyway.
I'd be using the 747 in the low HP class and the 748 TQ in the 200mm touring class straight away. It really is very good out of the box which needs very little sorting! Just remember to run heavier (about twice) oil in the diffs than you are used to on the 747 and you'll be set.
Old 12-28-2014, 02:52 AM   #337
Pass you soon...
I'll see if I can get a couple of those Vapex 1000 packs. Personally I hadn't heard of them. Thanks lil-bump!
Old 12-28-2014, 07:34 AM   #338
bighurt98's Avatar
Default Battery?
QUOTE=nitrodude;13742647]Which LIPO is everybody using?[/QUOTE]
If you have digital servos that can handle 7.4V, I use the Venom 1600. It weighs 78g and is 85x30x17mm and fits perfect lowered closer to chassis without touching chassis.
Capricorn C03/Matrix Tires/Novarossi
Capricorn RC USA/RC Target
Murnan Modified Motors
Desoto Racing
Team Gravity
bighurt98 is offline   Reply With Quote
Old 12-28-2014, 02:50 PM   #339
Start building the TQ...
Italboy is offline   Reply With Quote
Old 12-28-2014, 07:09 PM   #340
Bundy_Bear's Avatar
Robby:
What is this..... what happend to G4 project?
Enjoy the new build though
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 12-28-2014, 09:21 PM   #341
Enjoy the build. Trust me you will LOVE the car!
Old 12-29-2014, 04:18 AM   #342
Originally Posted by Bundy_Bear View Post
Robby:
Andrew
G4 project is in progress Andrew
Thank you..
Old 12-29-2014, 04:20 AM   #343
Thank you Dan
I wondered why on the TQ they put in heavier diff oils - should be normal with the new diffs.
Old 12-29-2014, 07:20 AM   #344
MeClown's Avatar
Default Novarossi Vir tus. Ceramic bearings factory tuned.
Hey everyone
Question as the Novarossi says its factory tuned, does that mean it is already broken in? If so then it's race ready out of the box?
Thanks again.
Michal
Old 12-29-2014, 08:24 AM   #345
lil-bump's Avatar
No. "Pre-Run" means it has went thru the break-in process(still not 100% broken in may need 2-3 more tanks). All of the high-end Novarossi engines say "Tuned"
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
