Like Tree8Likes
Old 08-19-2014, 08:49 AM   #226
lil-bump's Avatar
Trader Rating: 82 (100%+)
Originally Posted by Jamison R View Post
Do you know the bearing size?
I going to assume the bearing is a 3 x 6???
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-19-2014, 09:55 AM   #227
Originally Posted by dan_vector View Post
Well the natrix is finished and ready to go on the setup board. The car went together perfectly with no issues with the fit and finish. Superb just as I expect from Serpent.
Only issue I do have is that the throttle servo horn hits the radio box near full throttle. Trouble is I can't get my servo (Sanwa SRG-BLS v2) further in towards the centre of the car no matter what I try shimming etc. Anyone else have the same/similar issue? I'm thinking I'll need to try a different servo with a shallower gear case?
Yes me 2. I adjusted the servo more inward, but beware too much inward the servo horn will rub the radio plate. From what I saw the ball link will hit the rx box too, so you don't have to worry about it.
Mine can adjust the throttle EPA about 80%, brake about 25% (should be 5% more to go), it good enough.
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 08-19-2014, 10:54 AM   #228
Trader Rating: 25 (100%+)
I got it sorted. There are 2 options. One is a servo horn without the bend in like the serpent one and the other was extend the link rod. Trouble is by extending the link rod I felt that I was loosing some of the pull on the brakes but to be honest it seems ok.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 08-20-2014, 09:03 AM   #229
choisan's Avatar
Seems like low profile servos are the only option.
Any comment from the sponsored driver
choisan is offline   Reply With Quote
Old 08-20-2014, 09:27 AM   #230
lil-bump's Avatar
You could probably run a standard size in the steering position. but it's going to be tight.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-20-2014, 01:57 PM   #231
Yep. standard will fit in the steering servo slot but not throttle. Low profile is pretty much the standard for touring car I believe. Mind you if you look at Greiners car it looks like he's running one of the new AME standard size servos on the steering. I'll be sticking with my Sanwa low profiles as it's a nice neat package and it is perfectly balanced L/R.
Old 08-20-2014, 03:28 PM   #232
Trader Rating: 54 (100%+)
3x6 bearing for flex system
Jamison R is offline   Reply With Quote
Old 08-24-2014, 07:16 PM   #233
choisan's Avatar
Sadashi was using sanwa BZX regular servos.
http://s.ameblo.jp/asukacreate/entry-11901191207.html
Old 08-25-2014, 12:36 AM   #234
Originally Posted by acerracing View Post
We have just released our Serpent 748 Natrix Ceramic Nitride Pro Series Bearing kit on sale only $89.99 with FREE worldwide shipping.
I think your pricing is wrong because it is not 25% off storewide like your site suggests, unless I have misread it?
CDS70 is offline   Reply With Quote
Old 08-25-2014, 04:04 AM   #235
Julius's Avatar
I use the sanwa ers 971 on steering and throttle. Very good especially at the price. Michael Salven uses the same.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 08-25-2014, 05:18 AM   #236
I have those in my 747 Julius, for the 748 I went for the BLS v2's. So far I can't tell the difference so it does prove that the ERS series are excellent servos for the money! Only real difference on paper is that the ERS servos don't support SSR mode (but they work in SHR mode fine).
Old 08-25-2014, 09:22 AM   #237
Morganti also uses the ERS-971 servos.
desotoracing is offline   Reply With Quote
Old 08-29-2014, 08:27 PM   #238
Does anyone know a Sanwa receiver model that fits inside of the receiver box. It seems like Serpent goofed and made it too small for most receivers.
willcarrera is offline   Reply With Quote
Old 08-29-2014, 08:41 PM   #239
Trader Rating: 14 (94%+)
Most of recent airtronics(sanwa) fit. What do u use? Even 977 receiver box is tight fit but it accommodates most of them.
snuvet75 is offline   Reply With Quote
Old 08-29-2014, 10:02 PM   #240
The sanwa 451, 471 and 472 receivers all fit in the radio box. There seems to be more space in the 748's radio box than my 977!
