Like Tree6Likes
Old 08-16-2014, 08:21 PM   #211
Jamison R. The part # for the "Flex system" is 903576. You can find it here http://serpent.com/product/903576/. It consists of 2 small bearings, cone washers and flat head screws. You can't just place 2 screws in that area, and expect it to operate correctly.
Desoto Racing, Serpent America, NovaRossi, Enneti, SXT,Paintin Pete
Ashton Brinson is offline   Reply With Quote
Old 08-16-2014, 09:03 PM   #212
lil-bump's Avatar
Trader Rating: 82 (100%+)
Hmmmm interesting. I think this part is used for the 977 only . If there are inserts I think it would be included with part number 804355. Unfortunately there are no pics of this part.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-17-2014, 02:13 AM   #213
Trader Rating: 54 (100%+)
This looks very interesting. I hope it does fit the flex system on the 748.
Jamison R is offline   Reply With Quote
Old 08-17-2014, 02:27 AM   #214
Julius's Avatar
No that will not fit. The 748 flex system is similar but uses smaller bearings screws and top shim.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 08-17-2014, 03:05 AM   #215
Do you know the bearing size?
Old 08-17-2014, 09:13 AM   #216
Trader Rating: 23 (100%+)
Flex System 748 is P/N: 804355 as it's an option part as specified in the manual so I'm assuming it will have the extra bits needed (over the kit supplied parts 804330 & 804339)
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 08-17-2014, 09:27 AM   #217
Well the natrix is finished and ready to go on the setup board. The car went together perfectly with no issues with the fit and finish. Superb just as I expect from Serpent.
Only issue I do have is that the throttle servo horn hits the radio box near full throttle. Trouble is I can't get my servo (Sanwa SRG-BLS v2) further in towards the centre of the car no matter what I try shimming etc. Anyone else have the same/similar issue? I'm thinking I'll need to try a different servo with a shallower gear case?
Old 08-18-2014, 03:27 AM   #218
Les
Les's Avatar
Hey Dan, what is the race ready weight ?
Cheers
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 08-18-2014, 04:47 AM   #219
My car servo arm is close but set my sub trim to just get close to rx box. Then adjust linkage to get full throttle. Your not going to be able to move servo in towards tank.
Old 08-18-2014, 05:57 AM   #220
lil-bump's Avatar
I just had my first test and tune with the 748 and all I can say is WOW!!!!
This car is extremely quick in the turns. My final weight with Li-fe battery lp servos 1 futaba and 1 Hitec with 25 gram bias weight 1695 grams. I want to thank all of the Serpent team drivers that contributed the Natrix 748 project.
Pass you sooner...
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-18-2014, 06:58 AM   #221
Cheers
With full size tyres (62/60) carbon rim contacts its 1725gr. Novarossi Virtus, Sanwa SRG-BLS v2 servos, 1600 life pack (80gr), 25gr sliding weight and 2x 5gr serpent round weights under the 2speed shaft, my laps 2 wire transponder, Protoform VRS lightweight body (with protoform hard high downforce wing). Steel screws in chassis, alu screws in radio plate.
Old 08-18-2014, 07:01 AM   #222
I've ended up changing the servo horn to a sanwa horn and with a bit of dremel work made it find nicely. I wanted to keep the horn at a slight bias to the rear to maximum pull on the brakes. I will have another play with the stock horn and linkage lengths etc after my first runs with the car.
Old 08-18-2014, 02:02 PM   #223
shanwright's Avatar
Trader Rating: 25 (100%+)
Default Weight?
Pass you sooner...
Hi guys what is the minimum weight for the class you run in the US.
Steve Hanwright
shanwright is offline   Reply With Quote
Old 08-18-2014, 04:38 PM   #224
lil-bump's Avatar
1650 grams
Pass you soon....
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-18-2014, 05:23 PM   #225
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
The inserts from the 977 fits perfectly. I have been using them with no issues.
Walter Diaz
wad is offline   Reply With Quote
