Like Tree6Likes
Old 08-09-2014, 12:25 PM   #181
Trader Rating: 23 (100%+)
The loose shock top issue is because we've gone to the black soft membranes in the SS shocks. If you were to use the older firm clear membranes which are thicker than the soft blacks it allows the top hat and cap nut to screw down tight and the body doesn't rotate when adjusting ride height. I've found that just holding the top nut when adjusting is enough to prevent the shock from undoing. It's the same in new spare SS shock kits and my ERYX 3.0.
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 08-09-2014, 01:16 PM   #182
Why not use the old clear membrane instead,it more reliable.
Good thing about the 748 is I will have 3 sets of shocks instead of one since the 748 uses the same sa rcm shocks! Hooray ( do people still say hooray? Hehe) for that!
In the worlds I'm pretty sure its gona be hectic and adjusting stuff will be frantic! I will stick with the old membranes, too dangerous to use the new unless you superglue the top nut to the body?! Hmmm that's an idea.... But I need same membranes for all 3 sets of shocks. So I guess il go with the old membranes hehe
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 08-09-2014, 01:18 PM   #183
Originally Posted by lil-bump View Post
Low profile servos only for this kit?
Really? Standardservo doesn't fit?
Old 08-09-2014, 04:07 PM   #184
lil-bump's Avatar
Trader Rating: 82 (100%+)
A standard size in throttle position will not work ;it will hit the fuel tank. One of my low profile servos is out for repair.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-10-2014, 09:27 AM   #185
A standard size in throttle position will not work it; will hit the fuel tank. One of my low profile servos is out for repair.
There goes another 100dollars for me! What's the highest torque samnwa servo small size that has a .1second speed? Oh man this is a bummer having to buy another servo
Old 08-10-2014, 01:42 PM   #186
ERS-971 or SRG-BLS V2 or SDX-801
Old 08-10-2014, 01:43 PM   #187
Low profiles are standard in this class!
Old 08-10-2014, 01:45 PM   #188
The old clear membrane is too hard and makes it difficult to get low rebound in the shocks. The newer soft black membrane makes for a better shock if you don't like to run much rebound. If you want the old membranes you'll need to buy them extra. The newer spare SS shock kits now come with the soft membranes.
It won't be hectic at the worlds. There will be at least an hour and a half between runs.
Old 08-11-2014, 12:33 AM   #189
can all of these work with the 7.4 lipo? it does not say in the sanwa website. it says 6volts in the website
Old 08-11-2014, 05:23 AM   #190
I have run them in the past on lipo without issue. Strictly they are supposed to be 6v and I now run my BLS V2's on a 6.6v life and the servos are plenty fast enough. I have ERS-971's in my 747 and SRG-BLS V2's in my new 748 Natrix.
Old 08-11-2014, 12:47 PM   #191
Finaly, my Natrix is laying on my desk now! Some sleep first tho.
What is the advantage of the CF-aerodisks?
Fliggo is offline   Reply With Quote
Old 08-12-2014, 02:14 AM   #192
Trader Rating: 14 (94%+)
building tips:
1. Install front sway bar before the bulk head.
2. Pillow ball(for front sway bar) height:manual says 27mm but make it one more turn counterclockwise. Or the pivot balls will be tight.
3. Make sure to put 10mm screws(for shock mount) on FLw arms before putting them on chassis. It will make your life easier.
4. Connect throttle servo turnbuckle to pivot arms on top deck before putting the pivot arms in place.
5. Connect the steering servo turnbuckle to servo savor before putting the top deck on.
6. The shock rotation problem will continue. You need to grab the shock body when you turn the ride height knob. Or you will loosen up the cap. Try to use non serrated plier to save the threads on the body. Grabbing the top cap was not enough for me and felt insecure.
7. As mentioned above, you need 1 low profile servo for throttle. Steering servo can be whatever.
8. Do not mount the servo-receiver compartment on the upper deck yet until you install the futaba connector for the battery in the receiver.
9. If you are going to use transponder, make another wire for it. Then you can mount the compartment on the deck.
10. You can't use any other servo arms than the stock ones yet for this car unless there is pretty short one. The stock throttle servo arm is curvy and short. The stock steering servo arm is short. The steering one is very tight fit to the tank. If it's 1mm longer, then it will hit the tank unless you raise the tank or you're willing to do some modification.
Have fun. I hope you lessen your time on building with these tips.
Capricorn LAB C03
snuvet75 is offline   Reply With Quote
Old 08-13-2014, 01:02 PM   #193
Got my kit now too that I'll build this weekend. Had a quick look and found no 748 decals just generic Serpent ones no manual either but no worries as I've downloaded it already.
Old 08-13-2014, 01:34 PM   #194
Trader Rating: 54 (100%+)
My kit came with natrix and 748 decals.
Jamison R is offline   Reply With Quote
Old 08-13-2014, 01:39 PM   #195
I got both decals and manual. 1 sheet serpent ones and one sheet Natrix and 748 ones.
