Like Tree6Likes
Old 08-08-2014, 12:48 AM   #166
Aza088's Avatar
Originally Posted by Fliggo View Post
weight on that piece of engineering?
Not yet. i didn't build this car with light weight screws i want to see how much lighter it is in it's standard form. Will post findings soon.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 08-08-2014, 12:52 AM   #167
Aza088's Avatar
Originally Posted by TeamCarnage View Post
Nice! Worried about contaminated fuel?...
I'm guessing your commenting on the pressure line to the tank??
I have never ran a filter there and never had an issue.
There are all these theories behind filtering the gas entering the tank and most of all the theory of cooling the gas as it enters the tank. After long long long testing i have not been able to come to a conclusion on differences.
Basically -
Never had full go off or contaminate
Cooling the gas entering the tank we have never seen an advantage.
Les fuel tube or filters/coolers = less weight.
www.bluerc.net
www.hootrc.com.au
Old 08-08-2014, 12:55 AM   #168
Aza088's Avatar
Originally Posted by JOE SI View Post
Looked at the manual and only change I dont really like is the way the rear of the front upper arm mount. From what it looks like, it mounts right to the upperdeck and can easily break in a hard crash. Still loving the car though. Especially the rear flex system.
I don't think the problem with the top arm mount is the crash and break.
I think they have made it harder to remove the top deck. once those screws are removed the little threaded things fall out and are hard to get back in. during a race meet if you loose one your out!!
I look at it for hours. There is no other way to mount the top arm and save weight in that area.
There are many positives to the new design and how they have presented the kit.
lets see how it preforms on track.
www.bluerc.net
www.hootrc.com.au
Old 08-08-2014, 05:33 AM   #169
lil-bump's Avatar
Trader Rating: 82 (100%+)
Ok, every time I use blank rims to set ride height, the rear ends up 3mm higher.
I just use the qualifier size which in my case is 58/60 and set it with those and very rarely touch it. What do you set the rear at if the front is set to 1mm on blank rims
With blank rims I set my ride height to .55mm front and 1mm rear. If traction is high I start a little lower maybe .25 and .65 I use automotive feeler gauges for the measurement.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-08-2014, 05:46 AM   #170
lil-bump's Avatar
In the neighborhood of 1674 grams. This is with I believe low profile servos ,bias chassis weight and a Li-fe battery.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-08-2014, 08:21 AM   #171
For those little threaded things, just put thread lock. Without it, I lost so many 6mm screws on the top deck of the 747 before
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 08-08-2014, 10:08 AM   #172
Trader Rating: 14 (94%+)
W/ SS shocks, has anybody had any trouble loosening up the adjusting nut when you try to adjust the ride height? When I turn the ride height adjusting nut, whole shock body turns ending up loosening the shock cap. I've been grabbing the shock body with long nose plier when I adjust the height to prevent it but was wondering if there's any solution. My S411 also has SS shocks but it doesn't have that sort of problem. I believe over time, adjusting nut may loosen up but so far not. I applied some bearing oil on the rubber ring inside the nut but didn't help. Obviously I use much thicker shock springs in 747/748 than those in S411. That plays a factor too.
EDIT: I was referring to the adjusting nut, not the upper shock cap(in the first sentence).
Capricorn LAB C03
snuvet75 is offline   Reply With Quote
Old 08-08-2014, 11:57 AM   #173
lil-bump's Avatar
Take the ring off of the shock body and clean it. You may have some debris stuck in the threads of the shock body and or ring. Maybe the O-ring in the adjustment collar has swollen from the oil. If the threads are damaged on the shock then you have to replace the shock body.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-08-2014, 01:55 PM   #174
Pass you soon...
They are new shocks. No debris. No swelling. Maybe they are just too tight since they are new ones.
Capricorn LAB C03
Old 08-08-2014, 01:57 PM   #175
lil-bump's Avatar
Cross threaded???? Start swapping parts between the shocks
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-08-2014, 04:48 PM   #176
I always put oil on that.
Usually when I rebuild my shocks, I'll bleed the shock and when it gets on the threads I screw it all the way up so oil gets on the adjusting nut for the reason you're speaking of. Then I make a mark, so I know what a full turn is, loosen it 5 full turns and clean whatever oil is left over. It hasn't failed me yet
JOE SI is offline   Reply With Quote
Old 08-08-2014, 05:03 PM   #177
Aza088's Avatar
Mine did as well new out of the kit. The O rings a a little tight. If you have the ride height adjust nut all the way to the top it tends to grab when new. They will loosen up. Also really tighten top cap. Another tip is to have the spring loose when adjusting the spring tension nut. sometimes the weight of the car on the spring can cause the o ring to grab.
www.bluerc.net
www.hootrc.com.au
Old 08-08-2014, 06:08 PM   #178
lil-bump's Avatar
Basically -
I think Team C was talking about your numerous fuel filters on your 748...
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-08-2014, 11:13 PM   #179
Aza088's Avatar
Ah ha. In that case. There is no filter installed. Just 2 empty chambers. This is to bring the serpent tank up to 75cc. This was actually lighter than curling up fuel line.
www.bluerc.net
www.hootrc.com.au
Old 08-09-2014, 05:51 AM   #180
lil-bump's Avatar
Low profile servos only for this kit?
Elliott Hart
Serpent America
Desoto Racing Team
