Like Tree6Likes
Old 08-06-2014, 05:03 AM   #151
Trader Rating: 23 (100%+)
Originally Posted by GPXJOE View Post
I saw the manual in detail. It looks like they really cut the extra fat out buy it also makes me wonder about the durability. Some onepiece parts are now two small parts like the engine mount and the pinholder in the bottom front lower arm pins. Also the servo ears of steering and throttle share screws and one servo ear. I hope there will be enough stability in the screw tightness to keep the 2 servos steady. For sure this is a lighter car than 747. The world championships track needs a light car with.tons of flex and tons of center of gravity. A lot more 747 option parts before are now stock 748 parts which is good like the super short rcm shocks! Wow to that!and lowered shock towers.
Recieverbox and extension wire holder was just a masterclass!!
Lowfriction belts are now stock parts in the 748 according to the manual! Haven't checked the actual kit.
I wonder when the new diffs will be ready.
We had issues with the mono engine mount on the 747 cracking here in the uk. So I'm quite pleased the 748 has 2 separate mounts for the engine!
Serpent Viper 977e, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 08-06-2014, 06:55 AM   #152
http://serpent.com/product/804007/description/
t's up on Serpent's website!
Fliggo is offline   Reply With Quote
Old 08-06-2014, 08:01 AM   #153
Nice car, Bought one and have it black anodised.
I can only see 1 type of rear anti rollbar, does somebody know if there are more rollbars for sale (thickness)
rbakker is offline   Reply With Quote
Old 08-06-2014, 09:12 AM   #154
lil-bump's Avatar
Trader Rating: 82 (100%+)
Typo.. Serpent has the wrong tooth count for 2nd gear spurs listed on the 748 setup sheets. I 'm glad they now have clutch info on the setup sheet. I'm headed to the dungeon to begin my build.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-06-2014, 09:48 AM   #155
JJBinks's Avatar
Pass you soon...
Are you going to have it ready for Cincinnati? I am trying to just having a hard time finding the time i need to get it together.
Jon Strausbaugh
2016 Great Lakes Challenge Race Director
Great Lakes Challenge Coordinator - One Eighth Racers
www.ToledoOneEighthRacers.com
Serpent Natrix 748, Revenge .12, Desoto Racing, Futaba
JJBinks is offline   Reply With Quote
Old 08-06-2014, 10:33 AM   #156
lil-bump's Avatar
No and No. I can't make it to Cincy... that little thing called work got in the way.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-07-2014, 07:09 AM   #157
Aza088's Avatar
Ah ha. Ready for testing. Loving the transponder mount.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 08-07-2014, 09:13 AM   #158
Evo 13's Avatar
Looking good! Stupid question, do you put your own foams on those wheels?
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 08-07-2014, 09:58 AM   #159
lil-bump's Avatar
Most racers including myself set their ride height and track width with bare wheels. Those are normal foam wheels that have been shaved down to nothing.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-07-2014, 10:57 AM   #160
[IMG]https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-xfp1/t1.0-9/10557170_10204510189260880_7847102357591206964_n.j pg
[IMG]https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-xfp1/t1.0-9/10524630_10204510189940897_7777043494326911714_n.j pg
weight on that piece of engineering?
Old 08-07-2014, 03:04 PM   #161
TeamCarnage's Avatar
Trader Rating: 22 (100%+)
Nice! Worried about contaminated fuel?...
Nick Altieri
TeamNitro RC Club, New Home track- Ho Chunk Southland Expo, Lynwood IL
Serpent 748 Natrix WC, PICCO EMX "R", Spektrum DX4RPro, Futaba servos
977 EVO2, Matrix tires, Picco power.
Please drive responsibly
TeamCarnage is offline   Reply With Quote
Old 08-07-2014, 05:49 PM   #162
Trader Rating: 54 (100%+)
Ordered mine today from rcmarket. Can't wait to build it
Jamison R is offline   Reply With Quote
Old 08-07-2014, 09:17 PM   #163
Looked at the manual and only change I dont really like is the way the rear of the front upper arm mount. From what it looks like, it mounts right to the upperdeck and can easily break in a hard crash. Still loving the car though. Especially the rear flex system.
JOE SI is offline   Reply With Quote
Old 08-07-2014, 09:22 PM   #164
Pass you soon...
Ok, every time I use blank rims to set ride height, the rear ends up 3mm higher.
I just use the qualifier size which in my case is 58/60 and set it with those and very rarely touch it. What do you set the rear at if the front is set to 1mm on blank rims
Old 08-08-2014, 12:47 AM   #165
Aza088's Avatar
No. These are wheels that i have used in a race. Soaked then in acetone to remove the excess foam (nice and cleanly). The advantage of this is setting the track width is easier, also fitting the car into the scrutinisers box for maximum width is easier. Testing ride height is also a trick. I don't set my ride height using these tyres although i check to make sure that if i run out of tyres i have around 1-2mm ride height front and back at the most extreme.
The main reason i have these is for weight purpose. If i weigh the car with just the rims and i end up on 1650g (current weight limit) i know that after the final i will be over with minimal foam on the rim. Basically worse case i have no foam on any tyre the car will still be on the weight limit.
www.bluerc.net
www.hootrc.com.au
