Old 08-01-2005, 10:13 AM   #1
Default Removing a stuck thrust bearing from the clutch bell
Got my replacement parts this morning. I'm having a huge problem. My thrust bearing inside the clutch bell is stuck and i can't get them out. I can see the small bearings, but as far as removing that bell it's not. Any ideas on how I could get this bearing out, without tearing up the clutch bell? Thanks in advance.
Darthswan is offline   Reply With Quote
Clutch Bell Bearing Issue 843rcguy Nitro Off-Road 18 08-22-2008 10:09 AM
What can cause excessive clutch bell bearing failures? MattP Nitro Off-Road 13 04-29-2008 07:06 PM
wanted. Slapmaster thrust bearing or Axiom thrust bearing... Tron 101 R/C Items: Wanted to Buy 1 03-24-2008 09:34 PM
Clutch bell bearing problems rltanner Nitro Off-Road 14 02-20-2008 12:52 PM
Lube for thrust bearing in centax III clutch? stormperson Nitro On-Road 1 05-21-2004 04:54 PM
SEO by vBSEO 3.5.0
