Old 09-18-2014, 01:10 PM   #121
horchata's Avatar
hello.
the engine mount "lower" makes the engine touches the chassis? for xray nt1 2014, greetings.
horchata is offline   Reply With Quote
Old 09-22-2014, 12:26 PM   #122
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Default Handling differences between 13 n 14
Fellas quick question.........from someone who has ran both the 13 and now 14. What did you notice was different between the 2. good and bad? I'm in the U.S running on prepped tracks no sauce on tires! My buddy is telling me the 13 drives better than 14. Just want some other input
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "D815 PILOT" /FUSION X3LCFM / M2c / ko propo RSX / M11x / Novarossi
1evo RRR Driver is offline   Reply With Quote
Old 09-22-2014, 02:36 PM   #123
I would like to know also. I just picked up a 13 and not a 14 because I heard the same thing
JOE SI is offline   Reply With Quote
Old 09-22-2014, 05:31 PM   #124
Michael_T's Avatar
Trader Rating: 47 (100%+)
Send a message via MSN to Michael_T
I have run both the 2013 and 2014.
The main changes of the 2014 were introduced to improve the car on bigger tires (handout events) and on low traction tracks.
I only ran the car on high traction tracks (with smallish tires) and lap times were identical to the 2013.
Haven't tried it on a low traction track yet (which is it what it is really designed for).
The 2013 gearbox was bulletproof, and to be honest the new smaller gearbox on the 2014 felt exactly the same, so I don't really think there is much advantage there.
The new middle pulley was great - you can change your front belt without removing the radio tray.
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 09-22-2014, 11:25 PM   #125
Thanks..................all i needed to know
Old 10-04-2014, 02:54 PM   #126
horchata's Avatar
Default lower engine mount
the Crankcase at its lowest point in contact with the chassis and my question is żif it is normal to happen with the engine mount "lower"? and żif there is any risk of breaking some sort.?
Old 10-05-2014, 10:11 AM   #127
i have ran the lower engine mount the last 2 seasons with no issues
"Drew Q."
~Team Durango~RCAmerica~Futaba~Trak Power~Murnan Modifieds~REDS Racing USA~Hot Race Tyres
automagic302 is offline   Reply With Quote
Old 10-05-2014, 01:08 PM   #128
horchata's Avatar
and the engine touches the chassis?, what engine do you use?
Old 10-06-2014, 12:45 PM   #129
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
Do you guys have any tips to free up the drivetrain on this car. Or lighten drivetrain parts. I'm looking for better acceleration out of the corners. (Besides changing gearing)
ProE is offline   Reply With Quote
Old 10-06-2014, 02:38 PM   #130
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Is your clutch working as it should? I would start there.
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 10-06-2014, 03:53 PM   #131
horchata's Avatar
use a proper clutch adjustment.
Old 10-07-2014, 02:13 AM   #132
ProE's Avatar
The clutch is working fine. I'm looking for that little bit extra.
Old 10-07-2014, 04:49 AM   #133
horchata's Avatar
proof ceramic bearings and belts and pulleys very clean,another option is there is a spray for belts and pulleys which made some softer
Old 10-07-2014, 08:23 AM   #134
Besides clutch being right, my car has lightened shafts (2 speed and middle) lightened diff pins and out drives, composite front diff gears. The drive train is more free than any other car I've had. Pretty sure aluminum pulleys will make it even more free.
Old 10-07-2014, 09:08 AM   #135
ProE's Avatar
Smile
I already have the composite gears in front. Do you know of an online store that have the lightened 2 speed shaft in stock.
I will get the out drives as well. Thanks for the feedback so far
