Old 10-07-2014, 06:43 PM   #136
Bundy_Bear's Avatar
Originally Posted by ProE View Post
Do you guys have any tips to free up the drivetrain on this car. Or lighten drivetrain parts. I'm looking for better acceleration out of the corners. (Besides changing gearing)
ProE has most of it covered, although would change over to the rubber belts and would go Capricorn Kevlar pullies over the alloy ones.
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 10-07-2014, 11:25 PM   #137
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
Thanks for the info.
Are the capricorn pullies a perfect fit or do I need to modify something for them to fit?
Do you know if the size of the pulley are exactly the same? should I look at the pulleys for the co2/3 kit?
ProE is offline   Reply With Quote
Old 10-08-2014, 01:30 AM   #138
horchata's Avatar
no need to modify anything to put pulleys capricorn, just make sure when you buy them with the same number of teeth.
horchata is offline   Reply With Quote
Old 10-09-2014, 02:01 AM   #139
Bundy_Bear's Avatar
ProE:
As Horchata has said they are a direct fit apart from the brake pulley. You will have to stick to the Xray one for that. All the teeth count are the same as Xray. C01,C02 or C03 shouldn't make any difference. Even the Capricorn diffs will fit in the Xray too.
MissMooRC Racing
Old 10-15-2014, 06:31 AM   #140
Is there any really noticeable difference when running the monoblock engine mount and the brass motor mount?
I drove my (new to me 13) for the first time this past sunday just to get a feel for it. My last xray was a 2012 and ran a 747 this past season. I have absolutely no bad things to say about the 747, but xray just is a better fit for my driving.
JOE SI is offline   Reply With Quote
Old 10-26-2014, 02:44 AM   #141
Bundy_Bear's Avatar
Default Need some setup help guru's!
I am need of some setup advice...
My brother and I are both running the Xray NT1 2014 at England Park in Brisbane. This last meet in particular the grip was higher and we both had a few issues. The club has recently been sugar coating the track, but it is still quite bumpy. We normally run 37 shore front and rear trued to 60/62mm. We both had some traction roll on two particular corners that have a little more lean on the car.
Setup:
standard 2014 shock oil, pistons and springs. We are running inside hole on the shock tower with no rear sway bar.
Am wondering if we need to add the sway bar now or try a harder shore foam tyre front and rear or drop ride height?
Look forward to your thoughts and feedback.
Andrew
MissMooRC Racing
Old 10-26-2014, 01:09 PM   #142
Setup:
Andrew
Hey Andy
If the track is in hight traction condition I would make the car harder. For example, 1 or 2 hole in front (600), 2 in the rear (700). xray pinks all around. I would also suggest to put sway bar in the rear. You can begin with the standard one. Tyre shore hardness front 37/ 40 rear.
Regards
Rob
Italboy is offline   Reply With Quote
Old 10-26-2014, 03:51 PM   #143
Bundy_Bear's Avatar
Originally Posted by Italboy View Post
Hey Andy
Regards
Rob
Hi Rob
Thank you, I think the new shocks on the 2014 have a 3 hole piston front and rear with a 1.1mm hole. I think you get pistons with 1mm and 1.2mm holes in a 2 hole and 3 hole piston as well. Would you think changing to 2 hole piston in the front and going to thicker rear shock oil would be the go?
Andy
MissMooRC Racing
Old 10-26-2014, 05:12 PM   #144
bigtez's Avatar
Personally I would start by going to harder tyres and reducing the amount of roll while cornering, starting with stiffer sway bars and raising roll centres. Increasing the damping of the shocks will give you a bunch of other issues given the state of the track at the moment.
Terry Langham
www.qrccra.org.au
bigtez is offline   Reply With Quote
Old 10-26-2014, 07:48 PM   #145
Bundy_Bear's Avatar
Terry,
Thanks, I have tried 37fronts/40rears and balance just wasn't right, so will try some other options. It has only been this last meet that i have had issues and I would say it was from the extra entries in IC meet from the weekend before.
Andrew
MissMooRC Racing
Old 10-26-2014, 08:16 PM   #146
Scott B's Avatar
Trader Rating: 42 (100%+)
Setup:
Andrew
I had a traction rolling issue once, I talked to Mike Swagger and he suggested less caster(move upper arms forward). I haven't had anymore traction rolling issues and have been running my fastest times since making the change.
You could also just ca glue the front side walls, quick easy fix that's worked for me in the past...
Mugen Racing USA, Gizmo Racing USA, Sweep Racing Tires, R1 Wurks, Protoform...
"When I want the truth I go to the internet because that's the magical place where no one lies"...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 10-26-2014, 08:49 PM   #147
Bundy_Bear's Avatar
Scott B:
Thanks, I would have thought the CA glue on the sidewall would have been more to stop chunking the tire?
Andrew
MissMooRC Racing
Old 10-26-2014, 09:03 PM   #148
Scott B's Avatar
Scott B:
Andrew
It does that too...
Old 10-26-2014, 10:08 PM   #149
NITTO550's Avatar
Less caster works great, you can also raise the upper front arms, turn down dual rate a few notches wider track width and most importantly, ride height
There are only two ways to do things. The wrong way or my way!
Rich D..
~Mugen Seiki Racing MTX-6 ~,
Novarossi racing Engines ~Ko Propo, ~Avid Bearings..
VBC Racing Wildfire D07 ~LRP Electronics ~ Fantom Racing
NITTO550 is offline   Reply With Quote
Old 10-26-2014, 10:29 PM   #150
Bundy_Bear's Avatar
Thank you, I can adjust caster however the top front arms are all the way up already.
I would to perfect the ride height a little better as rear does sit up more then the front for my liking.
MissMooRC Racing
