Old 07-20-2014, 07:31 AM   #346
Grenade10's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Herrsavage View Post
Does this car use the DM-1 clutch bell and spurs? I.e. are there still spares available for my (unsellable..) DM-1? Thanks.
This car looks great, but I've got a brand new 1:7 DM-1 sitting here, and am scared to run it for fear of not being able to source clutch bells basically..
Yes same clutch bell, 2 speed and gears ......
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 07-20-2014, 09:01 AM   #347
Thanks.. The X3 GT looks awfully fast in the youtube video of the guy with the RTR running up and down his street. Says it's a stock Force 28.. I need to get a 28 in my DM-1 I guess..
-Team Associated RC8.2, RC8T CE, & SC8 with 1.) Argus A52/0801, 2.) RB Fire 11/2058 or 053, 3.) RB Blast V9/2045, 4.) Nosram RS.30RR/JP-4, & 5.) modded Nosram RS.21RR/086
-LST2 #1 with Losi 454 & LST2 #2 with Dynamite Big Red .28
-Ofna DM-1 with silver Mach 427/2047
-TT MT4 G3
Herrsavage is offline   Reply With Quote
Old 07-20-2014, 04:38 PM   #348
Photocycler's Avatar
Trader Rating: 34 (100%+)
Hey Guys, looking for a good lipo receiver pack. Something high capacity to run HV 7.4 servos.
Photocycler is offline   Reply With Quote
Old 07-20-2014, 07:05 PM   #349
Photocycler...this is the Lipo I use for my X3 and Sabre X3. Its from Amain. A ProTek#PTK-LP-RX2300-L-2S. 7.4V 2 cell 2300mAh RX8C receiver battery. No probs with it. I always balance charge @ a low amp setting (1Amp).
TLR 22 SCT full mod. 6.5 Orion
Jimmy Lauri is offline   Reply With Quote
Old 07-20-2014, 08:16 PM   #350
Evo 13's Avatar
Personally, I would steer clear from Protek, I had 3 of them die within the first few runs. I had much better luck with their life packs. Just my take.
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 07-20-2014, 09:40 PM   #351
T-Hawk's Avatar
LRP 2500. Have them in all my cars
-Ryan Newbury-
TomAHawk Racing - On-Time Services - XRay Racing - Sweep Racing - RoseCityScaleRacing.com -
T-Hawk is offline   Reply With Quote
Old 07-23-2014, 10:58 AM   #352
T-Hawk's Avatar
Is there any plans for an aluminum 2 speed holder and some more spring options?
-Ryan Newbury-
Old 07-23-2014, 05:02 PM   #353
technazi's Avatar
2.4mm silverish springs are on their way (so I've been told). Stock springs are 2.3mm and black.
What are you referring to when you say the 2-speed holder? Second gear housing is aluminum and so is the first gear mount. Are you wanting the center layshaft to be aluminum?
technazi is offline   Reply With Quote
Old 07-23-2014, 08:43 PM   #354
Welp. After a lot of tuning and messing around using 30% nitro, I was about to get a few solid runs in the 66mph range. Had the front left tire blow out and my baby went tumbling down the street. Ordered a set of Sweeps GT treaded / belted tires with the full foams. I pulled the the engine and took it apart and it looks like it's holding up very well. I'll try to get out this weekend and throw up more videos. I'm liking this car more and more each day.
Anyone know what parts to order to get a rear brake installed on this car? The front brake works, but it fades quickly and becomes utterly useless until it cools substantially.
trinitronman is offline   Reply With Quote
Old 07-23-2014, 09:15 PM   #355
It's bone stock.. Running on 30% nitro with added oil. I've actually had good luck with the two ofna .28 engines i've had. I now have slightly over 2 gallons of fuel through this one with no issues. I'm still running the same plug as well!
Old 07-23-2014, 09:18 PM   #356
T-Hawk's Avatar
The plastic uprights need to be aluminum.
-Ryan Newbury-
Old 07-23-2014, 10:13 PM   #357
Hey Guys, anyone who has installed the larger 150 cc tank - what did you do to mount it? With only one post being affixed to the tank, assuming I have to make my own post somehow?
Old 07-23-2014, 11:37 PM   #358
Looks fast as hell.. You've got a good tune on it. Which goes to show - it's not just the engine - but the owner who determines how well an engine runs.
I'm really torn on what direction to go in engine-wise for the DM-1 - always have been(had another one for a few years, but sold it..) I have numerous buggy 21's - including two RB Fire 11's(which are about as powerful as a .21 can get..), but have doubts that a .21 can push the gearing.. I've mostly run a Mach 427, but it's a bit old and worn out. I can't justify spending on a new .28 right now - not when I have 5-6 spare .21's laying around.. Maybe a trade or something.. I'd also prefer to not use a starter box if possible.. Switching back and forth with the buggy on my second box is a pain.. So yeah, stuck on engines.. My DM-1 is the 1:7 one too, so heavier than the X3 GT..
What other parts does the X3 GT share with the DM-1 btw? Sorry if that's been asked before...
-TT MT4 G3
Old 07-26-2014, 10:48 PM   #359
Grenade10's Avatar
If you use the same tank as used in the DM1, the chassis has all the holes. Go to IGT Hobbies site and look at option parts for DM1 or X3. I used straight posts from the DM1.
Old 07-28-2014, 11:58 AM   #360
technazi's Avatar
Why do the plastic uprights need to be aluminum? I've run the stock uprights, added a second rear brake on the back side, and never had any problems with stripping a gear. Why add weight and heat when the stock part works fine?
