Old 06-17-2014, 08:52 PM   #331
tbo713's Avatar
I want to use 13 -43 ring and pinion so who has that option
tbo713 is offline   Reply With Quote
Old 06-17-2014, 09:41 PM   #332
T-Hawk's Avatar
Nitro House. Look under the X3 Sabre buggy
-Ryan Newbury-
TomAHawk Racing - On-Time Services - XRay Racing - Sweep Racing - RoseCityScaleRacing.com -
T-Hawk is offline   Reply With Quote
Old 06-17-2014, 10:33 PM   #333
Yep!
TLR 22 SCT full mod. 6.5 Orion
Jimmy Lauri is offline   Reply With Quote
Old 06-22-2014, 11:15 PM   #334
Buggy Man's Avatar
Trader Rating: 42 (100%+)
I have one for sale. I decided to race just one class. This one has to go. Engine, manifold, pipe, and electronics NOT included. Run for 2 mins to ck set up.
$310 shipped with clear body
RC America, Hudy, IGT8.com
RCTarget.com, DesotoRacing.com
MugenRacing.com, Nitrohouse.com
Buggy Man is offline   Reply With Quote
Old 07-02-2014, 01:05 PM   #335
Grenade10's Avatar
Trader Rating: 37 (100%+)
Default Byrons Race
Went to the Byrons race this past weekend for the second outing for the X3. Car was pretty quick on practice day and first qualifier, but some engine issues that caused me to not finish, but was still 14th after the first round. Found a bad bearing in the engine and car was again good, but did not like the really high traction of the track for the last qualifier and mains. BUT, the car turned in better than almost all cars, carried speed just had some over rotation on exit that kept me from pushing the car hard. Qualified 16th, but had a build failure on trying to get rid of the over rotation on corner exit.
Next up is a return trip to LA, and looking forward to seeing the changes from the race early this year. I had a good bench mark as Andy Liu won the LA race and the Byrons race.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 07-06-2014, 06:00 PM   #336
Photocycler's Avatar
Trader Rating: 34 (100%+)
With the shortage of 80% kits and plethora of RTR's, considering a RTR kit as its only about $80 more. I want to make sure the RTR kit is the same exact as the 80% kit—are their any differences?
Has anyone started racing with the RTR and slowly upgraded the servos and motor?
Photocycler is offline   Reply With Quote
Old 07-06-2014, 11:20 PM   #337
Trader Rating: 125 (100%+)
wondering the same too
----Answer RC-USA----Stickit1 Racing----PT Racing Hawaii----808-RC----702 Raceway-----Dialed RC-----
Neesh is offline   Reply With Quote
Old 07-07-2014, 10:58 AM   #338
-R2-'s Avatar
Both cars are the same, only with engine, and radio gear and painted black body for the rtr.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 07-07-2014, 11:51 AM   #339
C@T
C@T's Avatar
The kit tyre delivered in Europe is a very soft non belted type.
Are those coming with the kit in the US are the same ?
If so, has anybody tryed to use them ?
C@T is offline   Reply With Quote
Old 07-07-2014, 11:58 AM   #340
I went ahead and ordered the RTR kit, with Amain having a coupon it was only 75$ more so figured why wait for the 80% with the outdoor season in Oregon being short on time.
Question, with the black body being hard to see for racing—what can be done aside from stickers to make it more visible, does vinyl wrapping work?
Old 07-14-2014, 09:05 PM   #341
I received the car tonight, its beautiful! I checked bolts, all look fine, the diffs feel smooth.
The gear mesh is perfect, I bought the clutch shim kit but there isn't really much play in the clutch bell—should it be really tight with no play?
I also looked to put red loctite in the drive shaft cups...looks like OFNA already did—the bolts are tight and I can see red liquid.
Anything else I should check, all bolts feel tight, only put some light blue loctite on the sway bar set screws.
Old 07-14-2014, 09:43 PM   #342
Grenade10's Avatar
Use 3 or 4 bearing in the front of the clutch bell. PM if you have questions.
Old 07-14-2014, 09:45 PM   #343
Grenade10's Avatar
Remove the grub screws and reset with red locktite, I've seen them come loose or get lost.
Old 07-17-2014, 10:53 AM   #344
I picked up one of these a few days ago. Like all RTR cars, i disassembled it and put it back together. I found 3 loose screws, none of them critical. I did not disassemble the shocks. Broke it in with 6 full tanks, then proceeded to PLAY!!! Swapped out steering and throttle servos (Hitec 645MG) and threw in a Spektrum 3ch .Temp at the plug after LOOOOONG full throttle runs is in the 223-227 range. I use it to play on the streets, so I think i'm going to leave it where it is. GPS runs in both direction averaging about 60.6MPH.
Videos on Youtube : Jhunt3r29
With a totally stock setup, what clutch bell can i switch to for higher speeds?
trinitronman is offline   Reply With Quote
Old 07-20-2014, 02:19 AM   #345
Does this car use the DM-1 clutch bell and spurs? I.e. are there still spares available for my (unsellable..) DM-1? Thanks.
This car looks great, but I've got a brand new 1:7 DM-1 sitting here, and am scared to run it for fear of not being able to source clutch bells basically..
-Team Associated RC8.2, RC8T CE, & SC8 with 1.) Argus A52/0801, 2.) RB Fire 11/2058 or 053, 3.) RB Blast V9/2045, 4.) Nosram RS.30RR/JP-4, & 5.) modded Nosram RS.21RR/086
-LST2 #1 with Losi 454 & LST2 #2 with Dynamite Big Red .28
-Ofna DM-1 with silver Mach 427/2047
-TT MT4 G3
Herrsavage is offline   Reply With Quote
