Old 06-01-2014, 08:04 PM   #301
Trader Rating: 48 (93%+)
Well Got my 1st Weekend under my Belt to run the car.. I must say the front clutch bell bearing is a MAJOR weak Point. After Talking to a guy that used to race the DM1 they had the Same Issue. Fix was to stack 2 of the 8x5x2.5 bearings and use ofna part Number# 10099
tcb22185 is online now   Reply With Quote
Old 06-01-2014, 09:11 PM   #302
T-Hawk's Avatar
Yep. And get yourself a BUKU clutch with a new clutch bell. A lot less heat
-Ryan Newbury-
TomAHawk Racing - On-Time Services - XRay Racing - Sweep Racing - RoseCityScaleRacing.com -
T-Hawk is offline   Reply With Quote
Old 06-02-2014, 04:48 AM   #303
Why not put a centex clutch on it.
Old 06-02-2014, 07:19 AM   #304
T-Hawk's Avatar
You can, but most rules say No Centex. They are trying to keep it "buggy" based
-Ryan Newbury-
Old 06-02-2014, 01:49 PM   #305
T-Hawk's Avatar
Will a regular round header fit on this car? Or do you still need the D style?
-Ryan Newbury-
Old 06-02-2014, 02:01 PM   #306
Yes A Regular Round Header will Fit. I did not even Run the Stock Muffler it Came with i went with the Matched Workz header and Pipe for the B2 i ran. I also ran a Losi and Jp3 setup in practice.
Old 06-02-2014, 02:16 PM   #307
T-Hawk's Avatar
Thank goodness Should have checked before ordering
-Ryan Newbury-
Old 06-02-2014, 04:54 PM   #308
Questions?? Questions for you guys.
I just bought the 80% X3 GT. I have a N.I.B. Force .28 engine and a N.I.B. Hyper .21 8 port race engine (non pull start). What engine to use to keep it legal for class racing. If both engines are legit...what one would you use? Also, recommend me a perfect Hytech steering servo. Don't mind spending the money on servos....how bout throttle and brake servo too! I am brand new to 1/8 GT on road. Thanks guys. Jimmy
TLR 22 SCT full mod. 6.5 Orion
Jimmy Lauri is offline   Reply With Quote
Old 06-02-2014, 08:56 PM   #309
Grenade10's Avatar
Trader Rating: 37 (100%+)
Actually, you want 3 or 4 bearings in the clutch bell. Shims between the crank end and long hat from the OFNA shim kit. Learned this with the DM1, that has the same clutch bell.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 06-02-2014, 09:00 PM   #310
Grenade10's Avatar
Go with the .21 for more RPM ...... IF YOU USE THE BUGGY GEARING ..... .28 for kit gearing. Servo 300+ torque for steering and throttle.
Old 06-02-2014, 09:03 PM   #311
Grenade10's Avatar
Also, change out the fiber brake disk to a metal with metallic pads. IGT Hobbies has them listed as option parts.
Old 06-02-2014, 09:53 PM   #312
Cool thanks Grenade for both replies!
Old 06-02-2014, 11:50 PM   #313
Buggy Man's Avatar
Trader Rating: 42 (100%+)
What size buku clutch needed?
RC America, Hudy, IGT8.com
RCTarget.com, DesotoRacing.com
MugenRacing.com, Nitrohouse.com
Buggy Man is offline   Reply With Quote
Old 06-03-2014, 03:16 AM   #314
http://www.bukupower.com/ClutchGT.aspx
Old 06-03-2014, 06:15 PM   #315
T-Hawk's Avatar
Your kidding me, a month out now
-Ryan Newbury-
