Savox SC-1258TG for 1/10?
The 1258 will work but in my opinion is not ideal for the smaller cars. If you already have it or got a good deal that will work well. If you are buying new take a good look at the 1251 I really like them as well as all the other 10th scale guys around here.
I would go with the Savox SC-1251 MG low profile servos. I use them in my S411 Eryx and as the throttle and brake for my 747. Low profile gives you a lot more room and they are a bit lighter. 125g is enough for a 200mm Sedan or a 190mm Sedan. You can find the in stock on Amain right now.
That for the feedback guys! I can get the Savox SC-1258TG for about $74 and the Savox Servo SC-1251MG for $59. That's Aussie dollars so would be a bit less in USD if you are comparing. So the pricing delta isn't that big between the two. Looking at getting 4 so will have a think about it.
The 1251s are great you'll love them. The only servo I will put in a 10th scale. You'll be happy with the speed and the smaller case is awesome. I'm not sure what you are putting them in but they made a big difference in my 747 and S411. A lot more room for everything else and save some serious grams.
The low profiles are ideal. The 1258 is a bit heavy for TC use and you'll love the extra space you get with the low profile!
hello to all
I use 1252 low profile powered directly from 7.2 and lipo spektrum receiver.
hello
hello
I am going to drop them in my RS4 evo+ to start with until I decide what to "step up" to for real racing. Thought it better to get a good set of servos from the start that I can re-use down the track.
Hello guys, new 2 the onroad thing. Got a mugen mtx4 with a collari .12 engine. Is this a pretty good engine. I also have a Ofna Hyper7 , thats bad.
