Savox SC-1258TG for 1/10? >
Old 01-24-2014, 05:22 AM
Ultra_Aussie's Avatar
Default Savox SC-1258TG for 1/10?
Hey guys, Would the Savox SC-1258TG be a good servo to use as a replacement for steering/TH on a 1/10 ?
Ultra_Aussie is offline
Old 01-24-2014, 07:08 AM
azeroth's Avatar
Trader Rating: 21 (100%+)
more than plenty i have been running the sc-1257tg for the last 2 seasons i have had zero failures
azeroth is offline
Old 01-24-2014, 07:32 AM
MIKE HINDS's Avatar
as long as your not using spectrum
MIKE HINDS is offline
Old 01-24-2014, 07:36 AM
I would go with the Savox SC-1251 MG low profile servos. I use them in my S411 Eryx and as the throttle and brake for my 747. Low profile gives you a lot more room and they are a bit lighter. 125g is enough for a 200mm Sedan or a 190mm Sedan. You can find the in stock on Amain right now.
The 1258 will work but in my opinion is not ideal for the smaller cars. If you already have it or got a good deal that will work well. If you are buying new take a good look at the 1251 I really like them as well as all the other 10th scale guys around here.
TerribleTy is offline
Old 01-24-2014, 08:33 AM
Yb2fast's Avatar
AGREED 100% !!! Have them in my XRAY NT1...they fit and perform awesome over a yr now !
Yb2fast is offline
Old 01-24-2014, 02:44 PM
That for the feedback guys! I can get the Savox SC-1258TG for about $74 and the Savox Servo SC-1251MG for $59. That's Aussie dollars so would be a bit less in USD if you are comparing. So the pricing delta isn't that big between the two. Looking at getting 4 so will have a think about it.
Old 01-24-2014, 07:32 PM
The 1251s are great you'll love them. The only servo I will put in a 10th scale. You'll be happy with the speed and the smaller case is awesome. I'm not sure what you are putting them in but they made a big difference in my 747 and S411. A lot more room for everything else and save some serious grams.
Old 01-24-2014, 09:00 PM
dan_vector's Avatar
Trader Rating: 27 (100%+)
The low profiles are ideal. The 1258 is a bit heavy for TC use and you'll love the extra space you get with the low profile!
dan_vector is offline
Old 01-25-2014, 12:14 AM
maver's Avatar
hello to all
I use 1252 low profile powered directly from 7.2 and lipo spektrum receiver.
hello
maver is offline
Old 01-25-2014, 03:12 AM
I have put up a wanted post in the Aussie section for the SC-1251MG. So I will see what comes back.
I am going to drop them in my RS4 evo+ to start with until I decide what to "step up" to for real racing. Thought it better to get a good set of servos from the start that I can re-use down the track.
Old 01-31-2014, 02:15 PM
Hello guys, new 2 the onroad thing. Got a mugen mtx4 with a collari .12 engine. Is this a pretty good engine. I also have a Ofna Hyper7 , thats bad.
hdurden is offline
Old 01-31-2014, 04:55 PM
I have gone with the SC-1251MG and they are on en route to me
Old 01-31-2014, 06:20 PM
I have a pair of those as well they will be fine in a sedan.
