using 28mm tires is this a good idea for serpent impulse
hi' is anybody there used a 28mm front tires for impulse,is that give any difference?how's the conversion pls.let us know,i heard that i need to replace my hex hub like wider than the stock impulse,where can i get this hub?and is this not going to rub on my steering block and how about my axle do i need to replace them too coz' if you going to use a wider hex hub,i might have a problem for putting the wheel nuts .
