Old 09-02-2002, 02:17 PM   #1
Default Picco .15
I got one of the new Picco .15 engines (Dark blue head, sliver crankcase)
Its a rotery carb & I have the main needle 4 1/2 turns out & the low end 2 turns out.
I'm running 16% nitro.
Its a new engine I've run about 3 full tanks in my T-max through the engine.
I cannot seem to get a tune.
The engine on idle 'surges' the revs rise & fall, its a constant rise & fall, very regular.
I know its not a lot of fuel to pass through an engine but after the 2nd tank I had it on my local touring track just to blip it around & heat cycle the engine.
When I gave a little bit of throttle it 'bogged'. As long as I blipped the throttle the truck moved but if I gave it a slight throttle up it would bog.
How many heat cycles should I give this engine 6 - 8?
Has anybody run-in one of these engines and how did you get on?
What glow plugs are you using?
Many Thanks
click, dublin is offline   Reply With Quote
F/S Picco JLR red dot.12 with 2607 picco pipe entitymugenmtx R/C Items: For Sale/Trade 5 01-31-2008 12:08 AM
picco p3-28 --- picco p7-r .21 --- jp3 p/h --- dynamite mach .28 for sale will g R/C Items: For Sale/Trade 9 07-27-2007 10:00 AM
JLR .12 Red-Dot Picco vs Z.12R Team Spec.3 vs Picco (#P1-4073) P1-R .12 RE EVO 3 Tur nickiphorosn Onroad Nitro Engine Zone 11 04-13-2007 09:18 PM
Is the OFNA Picco .27 and the Werks Picco .27 Identical? Chase Electric Off-Road 1 01-06-2006 12:09 AM
Trinity/Picco .12 RE, with Picco manifold, NIP sac R/C Items: For Sale/Trade 2 06-13-2003 08:07 AM
SEO by vBSEO 3.5.0
