Serpent 960....
#2851
To help explain the front roll bar situation, Not everyone has a trick swaybar tool, but EVERYONE in the pit area has a tuning screwdriver. With this in mind, quick last minute adjustments to the swaybar can be done by ANYONE on the fly. Also with flathead slots on the sides of the roll bar, you can physically see the position which can allow for more accurate swaybar settings from left to right.
Very happy with the kit. Wish I could post some photos but the site keeps saying 'Upload of file failed' even though the pictures are already under the noted limit. Anyone know how to fix this? Files are jpg, 153k.
#2852
The swaybar is adjusted on the fly, no need to loosen setscrew. It just bites the swaybar lightly enough to hold it in place, but you can still rotate the blades. Try it when you finish the car.
Plastic wrapping is vacuum sealed so you can never guarantee damage through corrosion and what not.
Different color bearings doesnt hurt, your still getting the same quality serpent bearing!
Pivot balls in the rear were updated, new material, new length, added strength. Be happy about these!
All the other manufacturers use the snapring, so even if you bought a mugen or a kyosho, youre going to need one!
But then again, as long as your happy with the kit, keeps a smile on my face too.
#2854
Check Kamikaze Toys and Hobbies, i think we have one.
#2856
Does the 960 08 kit includes both the OS1 and OS2 wheel axles and knuckles?
#2857
the Question
The chassis and top deck are the same as the 07 car! A few pages back Nigel posted a list of all the differences of the two! It is well worth the update guys! I know the kits are not as available as everyone would like, sometimes these things happen! The 08 car is the best car ive driven, and ive raced alot of cars! It is worth the wait!
#2858
Conversion Serpent 960 –07 to Serpent 960-08 OS1 front and rear
- The following parts are needed:
o 903252 Upgrade-set 960 to v08 OS1
Conversion Serpent 960 –07 to Serpent 960-08 OS2
o 903266 Wheel-axles FR OS2 (2)
o 903267 Lever alu/spring/pin OS2 FR (2)
o 903257 Upright OS2 (2)
o 903268 Wheel-axles RR OS2 (2)
o 903269 Lever alu/spring/pin OS2 RR (2)
o 903235 Shim 12x15x0.25 (10)
o 903255 Upgrade-set front 08
o chassis LCG must be modifed with dremel a little, to create space for the fr anti-toll bar movement and setting
Conversion Serpent 960 –07 to Serpent 960-08 OS2 front
Conversion Serpent 960 –07 to Serpent 960-08 OS1 rear
o 903253 Upgrade-set OS1 rear
Conversion Serpent 960 –07 to Serpent 960-08 OS2 rear
o 903254 Upgrade set OS2 rear
Conversion Serpent 960-08 from OS1 to OS2
- For the front the following parts are needed:
- For the rear the following parts are needed
Upgrade kit are now in the US and should start showing up at shops late the week.
#2862
I'll end up with a 960-08 with only OS1, so am wanting to check what I need for OS2.
#2863
3Racing Ti Turnbuckles
Car is almost finished now. I'll post a few highlights others might find helpful. Found these 3Racing Ti turnbuckles at almost the exactly same length as the Serpent ones (they are slightly thicker than the Serpent but I had no problems). I guess time will tell if the quality is similar as well.
#2865
Will Serpent be making OS2 wheels or will we have to buy them from other manufacturers? I presume a set of OS1 wheels comes with the kit as a set did with my original 960.
I heard Serpent have a pile of kits ready to ship, except for one part, the rear axle. Apparently ready to go in about 2-3 weeks.
