Serpent 960....
#1576
Originally Posted by Doug M
New optionalTeflon Brake Pads for your S-710, S-720 and S-960 are being shown on MyTSN.
http://www.mytsn.com/products/desc.asp?prid=4350
From Serpent's web site (http://www.mytsn.com/products/desc.asp?prid=4350)
*IMPORTANT* Mounting Information
Due to the material used, mounting these pads require more care and different techniques.
1. Degrease and then roughen the appropriate side of the steel brake plates using sand paper or similar.
2. Apply Impact adhesive (preferable heat resistant) to both pads (darker side) and plates on the correct sides.
3. Wait the required amount of time for the glue to harden (read the instructions of the glue)
4. Introduce the pads and plates to each other and press together as hard as possible (use of a bench vice is recommended).
I wonder if Serpent is giving up one of their current type of brake pads?
#1577
Originally Posted by border r/c
from monday there will be online
#1578
Originally Posted by going4#1
Interesting instructions. They seem to be saying apply glue to pad and brake plate, let dry, then squash together. How will the glue stick if it's dry? I've never heard of 'Impact adhesive'. Is that a special glue? What do others think?
PS: Make sure the steel brake plates are roughed up very well to insure a good bond.
#1579
Looking for setups
In a couple of weeks I'll be driving on a circuit I've never driven on. In fact, as far as I know, no 960 has ever driven on this circuit. It is HUGE! It's Hitec's circuit at their headquarters in South Korea. The lanes are about 8 cars wide. No joke. It has turns but there's really no major challenging areas. It's what you'd call a 'full throttle' track. I'm looking for setup suggestions to consider as I setup the car next weekend for practise. I've heard grip is high. Here's what it looks like. Those little specs you see are 1/10th cars!
#1580
Another set of photos for this mega circuit. I've never seen anything like it. I guess I'll be seeing a lot of it soon. I've got to drive it in a few weeks.
To see more photos you need to glue the following three lines together (the forum software doesn't adapt too well if it's one line). I have never seen a track this wide. Must be a world record.
http://www.photoi.net/album/public_r...&pAP=1&pTitle=
%BF%C0%C3%A2%21&pCatName=%C1%F7%C0%E5++++++++++++
&pCategory=AL000007&pNowPage=1
#1581
In some parts of the world "impact adhesive" is also known as "contact cement". Beleive me, when the opossing sides have cured for the proper time and are joined, it will be a very strong bond. Make sure you have the pad and plate aligned as close as possible because you will have only one chance once you press the two parts together.
#1583
Thanks Doug. Is contact cement the same as 'rubber' cement? A sort of thick yellow/white glue that dries fast, sticks to almost anything, and comes off very clean if you pull it off what you've stuck it to.
#1584
Originally Posted by TonysScrews
On the Serpent website they have two Spanish manuals available for download, but no English version?? Anyone have a link to an English version of the 960 manual?
Thanks and best regards,
easy reading
http://www.mytsn.com/products/dnlfil...anualWeb%2Epdf
#1586
The link works, so it's You....
right mouse button, save as......
#1587
Thanks for the reply. But not sure if it's just me, but the link doesn't work
ok, strange it works for me.. by the way.. go to www.mytsn.com and click on "products" and then click on "S960" then click on "Downloads" and then scroll down a bit and there you see the english manual. at the bottom "Serpent 960 - Instruction Manual"
have you installed a pdf-viewer? maybe thats why the link doesnt work?
#1588
Cheers, Mark.
#1589
#1590
Originally Posted by Bob Malphurs
Hey Serpent guru's....I'm looking for the "perfect" clutch setup. Can't seem to get it set for my sons (Robbie) 960! He wants it to hit hard out of the turns but I just haven't found the right combo of spring, end-play, etc. When I do get it to hit hard enough it overheats and fades out. I've looked in TSN but haven't found anything.
Another suggestion is to use the part 909520 (Centax II / III spring 1.8 (10mm)). You can get more tension out of the spring and I have good experience using it.
You can also make the 2-speed shoe-housing gap larger so when the car hits it's second gear, it will punch harder. I have not see a problem with 1/8th cars and a hard punching 2-speed but some 1/10th racers reported shreaded pinions as a result.
You should keep in mind there is a diminshing return on punch. Punch is simply a burst of acceleration as the shoe (spinning at crankshaft speed) hits the clutch bell, engages the 2-speed, which engages the front and rear wheels via belts. While it's not problem for the shoe or gears to spin fast other components cannot keep up as quickly. Typically tires spinning at a high speed can slip in accordance with grip (tire compound + surface condition). Belts can also slip. The clutch shoe can also slip. In the best case, a slipping tire or belt is just a waste of fuel but in the worst case the car is destabilized, wasting time, and perhaps getting into an accident.
Getting a good feel for the car is a always a goal but if you are racing, lap times are an objective measure of whether a certain clutch setting is better or not.
