Kyosho Evolva 2005 >
Kyosho Evolva 2005
Kyosho Evolva 2005
Old 09-14-2005, 04:16 PM
  #61
Erock's Avatar
Thanks Rich, files work great!
Man, that new tank seal sucks! I put my old tank back in. That new seal just wont stay put.
Erock is offline
Old 09-14-2005, 04:19 PM
  #62
Try a Serpent gasket. They don't collapse as easy.
Rich Browne is offline
Old 09-14-2005, 07:46 PM
  #63
jrabbito's Avatar
Hey Rich,
The uptravel you state on your setup sheets..is that measured uptravel? Or is the correlating numbers for the hudy droop guages?
Thanks a million again Rich,
John
jrabbito is offline
Old 09-15-2005, 07:29 AM
  #64
Default Uptravel
The way I measure uptravel of the chassis:
Car ar rest, shocks on, lift chassis until tire looses contact. That's the measurement.
I watch how the car comes out of the corner and adjust accordingly.
Yes, I use my Hudy tools to be sure my stops and shocks are set correctly.
Old 09-30-2005, 08:06 PM
  #65
Trader Rating: 57 (100%+)
can i substitute the evolva's 9mm ball screw (FM337) with mugen mrx-3/mrx-4 pivot balls? i don't know if they are the same. the LHS said they had some mugen pivot balls in stock. is there something out there better than the stock steel pivot balls for the evolva?
nismoflip is offline
Old 09-30-2005, 09:27 PM
  #66
hey, why you would need the mugen and what wrong with kyosho pivot balls ? i have not had issue with the original pivot balls.
speedy100 is offline
Old 09-30-2005, 09:31 PM
  #67
i only have changed the ball linkage from servo saver to muguen, i found those kyosho ball link come out very easily after one hit.
Old 09-30-2005, 10:43 PM
  #68
jeffreylin's Avatar
No. The Mugen ones are smaller. You can get titanium pillow balls although the stock FM337 is probably stronger.
jeffreylin is offline
Old 10-01-2005, 07:12 AM
  #69
You shouldn't be having a problem with the stock pivot balls. Do you need a set?
Rich
Old 10-01-2005, 03:11 PM
  #70
one pivot ball got bent out of shape from a big hit on the back straightaway. i didn't want to drive all the way to ace to get them. maybe i can buy some from you guys next time at rams? thanks.
Old 10-01-2005, 04:41 PM
  #71
I'm sure there will be some at the track - see ya next week
Old 10-03-2005, 11:30 AM
  #72
anyone know if FM405 (adjustable ) will fit on Evolva 03? thx.
silverM3 is offline
Old 10-03-2005, 01:54 PM
  #73
Erock's Avatar
Rich what size are the bearings that go in the new 05 bulkheads for the one- way and rear locker.
Anyone know where I can look at an 05 instruction manual?? I can't find it on the Kyosho sites at all.
Erock is offline
Old 10-03-2005, 02:03 PM
  #74
If that is the part number for the adjustable rear sway-bar it will fit the 03 and 05 both
Rich
Old 10-03-2005, 02:04 PM
  #75
KMW
KMW's Avatar
http://www.kyosho.co.jp/web/download...olva2005_m.pdf
KMW is offline
