Old 07-01-2005, 02:33 PM   #31
Hesky's Avatar
Originally Posted by joemugen
i do not think it is the torgue of the servo that will cause the spring not to be strong enough to make it return. i think it is more of how the gears are geared down, if they are lubricated, the tightness of their mesh, and if they are all steal. i think the combined factor of these elements will determine if the servo will be too tight to come back. the bottow line is all servos are motors with gears attached. how well the gears are disigned and maintained will give you the smoothness of the servo.
uhuh thats rite, the torque of a servo and the ability of the spring to return the servo is unrelated. I guess decent servos are ballraced have stronger faster motors so low gearing it isnt as necessary to produce decent torque so your end result is a servo that is much easier to rotate at the horn end.
Hesky is offline   Reply With Quote
Old 07-02-2005, 10:20 PM   #32
ntc3freak's Avatar
my bad
ntc3freak is offline   Reply With Quote
SEO by vBSEO 3.5.0
